Front brake light switch
- Ray J
20 Apr 2007 07:54
I need to put a switch on my front brake lever. The current switch is in the brake line and does not turn the brake light on until I am squeezing fairly hard. I would like to put another switch on the acutal brake lever, so when I squeeze the handle, the switch turns on the light.
Any suggestions? Thanks
- Sandy
- Fly High,Tony
Re: Front brake light switch
20 Apr 2007 08:17
I'm using a Ho**a CB600 front brake lever set-up with the master cylinder,and it has the micro-switch built into it.
I had the SAME problem,so I went this route...much better!
Go to a bike bone-yard and look for something newer that HAS that style.You should be able to adapt just about any set-up to Your bike.
Just pay attention to the mirror mount.The one I have didn't have one,so I had to make one up.
1977 KZ1000 A-1
- ltdrider
20 Apr 2007 08:22
Ray J, you have the same model as me, and my front brake acts the same way. That pressure switch in the brake line takes some squeezin' before I get a light. I'm careful to touch my rear brake pedal when I brake, even if I don't need it, so the guy behind me gets a signal.
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
Greensboro, NC
- davenkids2001
20 Apr 2007 09:48
I have the same problem. I even changed the switch because I thought a newer switch would work better(at lesser of a squeeze on my front brake handle) but it is the same. It really takes a lot of force to initiate the brake lamp. So I do the same as ltdrider...I simply have trained myself to use the rear brake to get the brake lamp lit. At least the rear brake switch sensitivity is adjustable. In fact, I adjusted the rear switch to initiate the brake lamp at the slightest pressure. Now I can just 'tap' the rear brake and get that tailgating jerk off my butt!
Dave and Janet
Great Lake State
1979 650SR
Great Lake State
1979 650SR
- shaftie1100
20 Apr 2007 12:29
You could also switch to a ltd. front master cylinder... I just installed a new front end on my ride, and I have one sitting here for an 1100, but it should work just fine. The button is under the shoulder of the brake lever, not on/in the brake line.
PM me if you are interested. Any reasonable offer accepted. At this point, I'm just trying to recoup some of my losses from the new parts.
- Kiwiz
21 Apr 2007 03:30
What about putting a new hydraulic activated switch in the brake line?
I have a 1000 J and the banjo bolt at the master cylinder looks identical with that on my Ducati. All you do is replace the standard banjo bolt with the one with the switch inside. If its anything like the J the front brake light switch is at the MC and the connectors should be close by. No need to replace MC
I put one of these in a ducati Monster to replace the erratic OEM switch: works perfectly. Bought from Bevel Heaven in US
www.bevelheaven.com/productinfo.html
whilst these are designed for Brembo brakes they might well fit and are ISO metric. Also I suspect these same switches are available for Jap bikes
Post edited by: Kiwiz, at: 2007/04/21 06:34
- Ray J
21 Apr 2007 09:02
Thanks guys. I posted this a few years ago and no one had this problem. I thought I was alone in this crazy mixed up world.
I do what you are doing now, ltdrider. I hit the rear brake when braking. This is not a problem at high speeds, but in stop and go intersections, going 5mph, I have to constantly keep my foot on the brake. Kind of a pain. Nice pics by the way.
Kiwiz, does that banjo bolt fit in where the switch is now at? I have not had the chance to look at mine yet. It is at a friends.
- Kiwiz
23 Apr 2007 01:03
Ray J,
I have a J which has the front brake switch activated off the MC lever, Whilst this gives me no trouble my ducati one (similar) did.
The banjo bolt is that bolt which holds the hose to the MC. These can be replaced with a new bolt which incoporates the brake switch. Picture of it is on the bevel heaven site. Unscrew old, check diameter and length, cut new to length if necessary, replace and bleed.
My feeling is that the standard Jap banjo bolt could be replaced by one of these. Check the diameter and length but it was ISO metric thread. Maybe you consider this a pricy fix but over here no front brake switch working means a failed road test, and replcaing old Ducati crap with new Ducati crap didnt seem a smart option
Post edited by: Kiwiz, at: 2007/04/23 04:03
- AR15Ron
23 Apr 2007 04:08
I swapped my front master cylander to one from a police model and it had the switch built in. Now I have both switches
Whole thing cost about $15 on ebay with the handle and all the brake lines included.
- Ray J
23 Jul 2007 17:40
I am finally getting around to fixing this brake problem.
If I am understanding Kiwiz right, I replace the bolt #25, that connects the front brake hose, with a banjo bolt like this:
stores.sportbiketrackgear.com/Detail.bok?no=426
Is that right?
Post edited by: Ray J, at: 2007/07/23 20:42
Post edited by: Ray J, at: 2007/07/23 20:45
Is that right?
- Kiwiz
09 Aug 2007 16:09
Ray J
yep thats right replace the banjo bolt (part#25)with the switch you have shown Although I got mine for a Duc from bevel heaven what you show is identiacl and mine works a treat. Just be careful of the length of the threaded part. Mine was slightly too long but I packed it out with an additional washer
- rstnick
09 Aug 2007 20:46
I need one of those too, my front brake light doesn't work at all.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
