rear wheel id
  • Dutch Masters
  • Dutch Masters's Avatar Topic Author
rear wheel id
19 Apr 2007 19:21
#132045
I have a 79 kz400, that I thought had all original parts. However, I ordered a wheel brake shoes from Z1. But they didn't fit. the shoes were a little large. so I'm looking for help to figure out what rear wheel I have. I have attached some pictures if those will help with the ID.
Post edited by: Dutch Masters, at: 2007/04/19 22:23
  • Dutch Masters
Re: rear wheel id
19 Apr 2007 19:27
#132049
new guy working on getting the pictures attached
  • Dutch Masters
Re: rear wheel id
19 Apr 2007 19:29
#132051
another pic this is located inside the drum area
MAX DIA. 159.75mm
Post edited by: Dutch Masters, at: 2007/04/19 22:31
  • Dutch Masters
Re: rear wheel id
22 Apr 2007 17:10
#132837
I think that I have started to get the hang of this. Here is a link to some pics. s150.photobucket.com/albums/s88/dutch_masters/rear%20wheel/
  • steell
  • steell's Avatar
Re: rear wheel id
22 Apr 2007 17:42
#132846
Here is another pic for you.
Personally, I'm wondering if you got the right brakes shoes?
  • Dutch Masters
Re: rear wheel id
23 Apr 2007 07:49
#133018
So do you think that the wheel looks like the factory wheel for the 79 400 LTD? If so I will order another set of shoes and hope the first set were just out of spec.
  • steell
  • steell's Avatar
Re: rear wheel id
23 Apr 2007 21:50
#133318
What exactly do you mean by "the shoes were a little large"? To thick, or to wide?
  • Dutch Masters
Re: rear wheel id
24 Apr 2007 06:15
#133393
With the shoes assembled on the brake, they were about 1/4 inch to large in diameter to fit inside the drum on the rear wheel. The backing part of the shoes fit on the brake accuator parts correclty, so I think the issue was the thickness of the friction material.
  • steell
  • steell's Avatar
Re: rear wheel id
24 Apr 2007 07:07
#133421
Did you retract the brake cam all the way? It should be vertical so as to not spread the shoes apart. the lining on motorcycle brake shoes is usually not very thick, maybe 1/8" or so, and being a 1/4" to large overall means that to fit you would have to take off all the lining. But the shoes fit the back plate, so that don't make any sense. Recheck and make sure the shoes are in place and assembled properly.
Can you post some more pics, including one of the shoes assembled on the actuator (brake hub)?
  • Dutch Masters
Re: rear wheel id
24 Apr 2007 08:29
#133446
Well I thought that I had them assembled correctly. I have already sent the brake shoes back, before I took any picks. I have ordered another set from Z1. Hopefully I will put them on correctly. If I have the same issue I will post pics of the accuator assembly. If they fit I wiil post pics of me riding the bike on its maden voyage.
Thanks for the help so far.
  • steell
  • steell's Avatar
Re: rear wheel id
24 Apr 2007 15:52
#133573
Not that I have been much help :D
Did you check locally with Cycle ReCycle on 10th street in Indy? If they have a set in stock it would give you something to compare.
  • Dutch Masters
Re: rear wheel id
24 Apr 2007 18:53
#133624
I have not checked with cycle recycle. If the new ones don't fit I will head over there and see if they have a set to compair to.
