struts
  • demented
  • demented's Avatar Topic Author
struts
18 Apr 2007 15:41
#131623
can and will someone please tell me if there is a website where i could check out some rear struts and possibly order or get an idea how i wanna make a set?:blink:
  • racer54
  • racer54's Avatar
Re: struts
18 Apr 2007 15:59
#131625
Go to www.pingelonline.com . Find the section about wheelie bars and they have an area where you can design struts...length, etc.... and they will make them to your spec.s Not sure of the cost but that should be on there somewhere too.
  • 77KZ650
  • 77KZ650's Avatar
Re: struts
18 Apr 2007 16:00
#131626
you just need a couple pieces of aluminum the right lenght and drill 2 holes in them. check out your local metal dealer I bet you can get the stuff for $10
07 MDP Rookie of the Year
  • demented
Re: struts
18 Apr 2007 16:56
#131642
thx for feedback guys . i have thought of just making my own. i do work in an aluminum foundry :)
  • 77KZ650
  • 77KZ650's Avatar
Re: struts
18 Apr 2007 19:13
#131697
Im suprised wireman hasnt jumped in with a pic, I know he has expirience with them. My guess is that you would need 3/8 by 1 by 13 or so inches, maybe longer or shorter depending on desired ride height
  • ninety8problems
  • ninety8problems's Avatar
Re: struts
07 Apr 2009 19:14
#279303
I just bought some aluminum struts off of ebay, and the upper thru-holes seem to be too big. Stupid question...is there supposed to be that much "slop" between the thru-holes and the bushings? Or, is supposed to be a slip fit...nice and tight with zero slop?
  • PLUMMEN
  • PLUMMEN's Avatar
Re: struts
07 Apr 2009 21:25
#279350
i dont run struts on streetbikes,put a set of short rear rear shocks set on softest setting youll be much happier!B)
  • racer54
  • racer54's Avatar
Re: struts
08 Apr 2009 10:36
#279528
You're just getting old or are you just a wuss? What do you need kidneys for at your age? Leave the shocks to us young guys! Just be sure to check you have enough clearance at full squat. Figure in rider weight if you have that option. Shocks? We don't need no stinkin' shocks! :laugh:
  • Locozuna
  • Locozuna's Avatar
Re: struts
08 Apr 2009 11:01
#279536
I made the bowl turn red once (not from struts).I don't plan on doing it again. With the roads around here it would be a sure bet I'd do it again or the science channel would be doing a documentary about my Killer ASSterROIDS!!!
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
