What model front end is this?
  • Muddy
  • Muddy's Avatar Topic Author
17 Apr 2007 08:17
#131069
I started ripping apart the 650 csr I have to build a cafe racer, and I'm trying to figure out what type of front end I have. I know its not the stock setup, but what is it?
It is a leading axle air fork setup with mag wheel and dual discs. The forks are kayaba and have a kawasaki label on each leg. the calipers are single piston tokico units.
I need to figure out what it is so I can sell/trade this front end and get a kz650 c/b front end. Or even stock CSR.
  • StreetfighterKz
  • StreetfighterKz's Avatar
Re: What model front end is this?
17 Apr 2007 08:35
#131076
Do you have pictures? What you describe could be for anything from a 650 through an 1100. Do you have fork tube diameters? Any more info will help.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
17 Apr 2007 08:36
#131077
A pic would REALLY help out,Bud.B)
1977 KZ1000 A-1
  • steell
  • steell's Avatar
17 Apr 2007 13:14
#131199
You very well may have a CSR front end with wheels and brakes from another model. The CSR's had leading axle forks according to jarle.eltelevest.no/Kawasaki/Series/Z/650/z650.htm
  • Muddy
18 Apr 2007 11:49
#131564
Here is a picture of the front of the bike. www.hifidefinition.com/ebay/336.JPG
Post edited by: Muddy, at: 2007/04/18 14:50
  • mariozappa
  • mariozappa's Avatar
18 Apr 2007 13:07
#131585
Looks like an 82 csr bike with possibly just an 83 csr front rim and brakes, could be the forks too. I'm not sure if the axle is the same size.
Have a look at buykawasaki.com and compare part #'s.
1977 KZ650C1
and the KZ650/KZ750 Conversion ;)
  • steell
  • steell's Avatar
18 Apr 2007 13:09
#131586
LTD front end, probably a KZ750 since the fork tubes are so far above the top clamp.
That's my guess anyway :)
  • mariozappa
18 Apr 2007 13:14
#131587
750/4's and 650 csr and sr's have a different shaped dust cover boot on the forks than the older models, which are bigger. If that helps any.
1977 KZ650C1
  • The Gringo
  • The Gringo's Avatar
  • ¡Usted no necesita otra motocicleta!
18 Apr 2007 14:12
#131602
The frontend, wheel and brakes look just like what is on the 750 LTDs that I have. It is not a 650 CSR frontend because they did not have the mounting for the extra disc on the right side. Due to the CV carbs on it and the type of tailight I would say you have an 82 model.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
