Well that won't work! Fork seals
  • Frank
  • Frank's Avatar Topic Author
16 Apr 2007 16:56
#130891
With some advice from the forum and my trusty kawasaki service manual tonight i tackled my fork seals on my 1985 ZN750LTD. The local kawasaki shop does not have the microfiche for this bike so me "ass-uming" i thought the fork seals for a spectre would be the same(since they are both covered in my manual). WRONG!!! They are actually 2-3mm taller than what i need but they are the right diameters. So 1) grind down the original spacer(Ya right lol) 2) Take the $20 loss and see if i can find the actual ones. The only place i have found is ATHENA and they have ones for the 700 which I know is the same but yet agian the local shops seem not to have these either. Thought i would post this so no one will end up with a job taking longer than it should have. Oh and for all those saying you need an impact gun to get the damper rod bolts out......wrong and i know these have never been touch. A little muscle and patience will do it.
  • wireman
  • wireman's Avatar
Re: Well that won't work! Fork seals
16 Apr 2007 18:58
#130927
an air ratchet just makes it easier to take them apart so you dont have to hold the rod from spinning while you remove the bolt;)
