Replace fork seals w/out fork disassembly?
  • jeffreygp
  • jeffreygp's Avatar Topic Author
16 Apr 2007 16:29
#130884
Hello, I would like to ask,if is it possible to replace the fork seals without completely taking apart the forks. I read somewhere in the archives that this is possible with a kz750 with air forks. Can you also top up the fork oil without opening the top cap, using only the drain port to put in some oil? I would greatly appreciate your inputs.:)
Post edited by: jeffreygp, at: 2007/04/16 19:41
  • archaicbiker
  • archaicbiker's Avatar
Re: Replace fork seals w/out fork disassembly?
16 Apr 2007 16:45
#130887
Im new to the KZ, but they are almost the same as my XS and I did it on it. I removed the tube from the bike, removed the bolt at the bottom and pumped the oil out. Make sure its aiming into a bucket or something or you will have a mess. Then I turned it upside down and slid the bottom half of the tube off. Removed/replaced the seal and slid it back on. Then I measured out the proper amount of oil and squirted it into the tube thru the bolt hole. Put the bolt back in and there ya go. :cheer:
  • harm
  • harm's Avatar
  • Tom
16 Apr 2007 16:50
#130888
I did try this one time on my dirt bike forks. I was told to drill some holes in the seals and thread a couple screws into them and then use a pliers on the screws to lift the seal out. In my opinion it's not worth it. The forks are not that hard to diassemble, clean and re-assemble.
Anyway, thats my two cents...
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
  • H1Vindicator
  • H1Vindicator's Avatar
Re: ----
16 Apr 2007 20:07 - 20 Feb 2013 18:54
#130943
Last edit: 20 Feb 2013 18:54 by H1Vindicator.
  • steell
  • steell's Avatar
16 Apr 2007 20:49
#130968
I pop the seals out with air pressure, but most of the time I have to heat the fork around the seal to get it to pop out.
  • jeffreygp
19 Apr 2007 14:13
#131949
Thanks guys:)
  • kzwolfsr
  • kzwolfsr's Avatar
21 Apr 2007 21:38
#132663
I hit my seals with a screwdriver and dinged them out. I couldn't get the forks fully apart so O just repeatedly flushed them til the oil was clear
Original man of the Caribbean
  • H1Vindicator
Re: ----
22 Apr 2007 08:05 - 20 Feb 2013 18:54
#132715
