Longer swingarm
- chris insull
Longer swingarm
15 Apr 2007 03:41
I'm considering a longer dragbike style swingarm for my '78 Z1-R. Any recommendations? Modifying a stock one or adding one from another make/ model? Any pics or links would be appreciated!! TIA.
- Lorcan
- Speed Loony
Re: Longer swingarm
15 Apr 2007 10:02
The stock one is pretty bendy so lengthening it is just going to make it even weaker. I'm not sure about the Z1R but on my 750 all the modern Suzuki arms will fit - GSXR600/750/1000/Busa etc - and can be easily extended either with welded in drag slots or with bolt on extensions. Here it is with a GSXR750 arm fitted. Later on I swapped it for a 600 arm which is similar but unbraced and had it extended 5".
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
- chris insull
Re: Longer swingarm
15 Apr 2007 16:26
Thanks Lorcan. I thought I'd seen some pics of Z1-R's with extended swingarms on this forum before... Probably were using Suzuki parts, just not sure which ones and/ or what the extensions were. Any help is much appreciated!
- 77KZ650
Re: Longer swingarm
15 Apr 2007 17:06
the z1r is a dual shock setup correct? unless you are doing a mono conversion, I would recommend the boxed aluminum gs1100 swingarm. it is a couple inches longer than stock already, and it is pretty stout if you want to extend it further. wireman is doing this on his turbo bike
details here
details here
07 MDP Rookie of the Year
- wireman
Re: Longer swingarm
15 Apr 2007 17:13
77KZ650 wrote:
thats a gsxr arm im using it was a mono shock but made shock mounts into extensions for the dual shocks.i figured the big hole from stock mono shock would be a good spot to stick a bottle;)the z1r is a dual shock setup correct? unless you are doing a mono conversion, I would recommend the boxed aluminum gs1100 swingarm. it is a couple inches longer than stock already, and it is pretty stout if you want to extend it further. wireman is doing this on his turbo bike
details here
- 77KZ650
Re: Longer swingarm
15 Apr 2007 17:17
wireman wrote:
damn drag bike is eating all the bike funds now:whistle:
ah so it is, i forgot, its been so long since you posted anything new about it:P heck, almost as long as i have gone without working on my 65077KZ650 wrote:thats a gsxr arm im using it was a mono shock but made shock mounts into extensions for the dual shocks.i figured the big hole from stock mono shock would be a good spot to stick a bottle;)the z1r is a dual shock setup correct? unless you are doing a mono conversion, I would recommend the boxed aluminum gs1100 swingarm. it is a couple inches longer than stock already, and it is pretty stout if you want to extend it further. wireman is doing this on his turbo bike
details here
- wireman
Re: Longer swingarm
15 Apr 2007 17:24
77KZ650 wrote:
im starting to move a little bit.
yeah thats the problem with doing 35 projects at once damn the Serious.Attention.Deficit.Disorder !wireman wrote:ah so it is, i forgot, its been so long since you posted anything new about it:P heck, almost as long as i have gone without working on my 65077KZ650 wrote:thats a gsxr arm im using it was a mono shock but made shock mounts into extensions for the dual shocks.i figured the big hole from stock mono shock would be a good spot to stick a bottle;)the z1r is a dual shock setup correct? unless you are doing a mono conversion, I would recommend the boxed aluminum gs1100 swingarm. it is a couple inches longer than stock already, and it is pretty stout if you want to extend it further. wireman is doing this on his turbo bike
details here
- Lorcan
- Speed Loony
Re: Longer swingarm
:laugh: :laugh: :laugh:
I'm picking up another arm for my 750 at the end of the week, this will be it's sixth arm, including the original! This one is 13" over, making the bike 68" wheelbase, the maximum allowed in our superstreetbike class (not that it would ever be competitive in that class but hey). I'll post some pics when it's slotted in. It's getting the one piece fibreglass body off my old bike too which has an extended tailpiece to suit the longer arm.
760cc - 8.69@162mph
- donthekawguy
Re: Longer swingarm
16 Apr 2007 04:11
There are a couple on ebay right now.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
