18\" wheels on a CSR
  • Muddy
  • Muddy's Avatar Topic Author
10 Apr 2007 10:13
#128521
Are any 18" whels a direct swap on a 82 CSR? If not what am I looking at to change things over?
  • H1Vindicator
  • H1Vindicator's Avatar
Re: ----
10 Apr 2007 10:18 - 20 Feb 2013 18:44
#128524
Last edit: 20 Feb 2013 18:44 by H1Vindicator.
  • apeman
  • apeman's Avatar
Re: 18\" wheels on a CSR
10 Apr 2007 17:16
#128624
If you want to upgrade to a rear disc brake, I believe the KZ750E rear wheel (18") and brake components would be a reasonable swap. You would likely need to add a bolt mount point for the rear brake arm onto your swingarm, but that doesn't seem like major surgery. Take a look at the KZ750E1 diagrams on the Kawasaki.com parts diagram website.
Petaluma and Truckee, CA -- member since Jan. 23, 2003;
PREVIOUS KZs: 1980 KZ750H with 108,000 miles; 1980 KZ750E with 28,000 miles; and KZ750H street/cafe project, all sold a few years back.
This is what I do for fun, not for work. It is art, with a little engineering thrown in.
  • H1Vindicator
Re: ----
11 Apr 2007 07:47 - 20 Feb 2013 18:44
#128774
  • The Gringo
  • The Gringo's Avatar
  • ¡Usted no necesita otra motocicleta!
Re: 18
11 Apr 2007 14:56
#128891
As H1Vindicator wrote the 550 standard wheel will work as will a wheel from an 80 650-F, although that was a model made for only one year so your chances of finding one are not real good.
The 440 wheel will not work it uses a smaller rear brake setup.
Apeman is correct about using a wheel from a 750 E model but it would require either using the 750 swingarm or welding up a bracket to yours. The good news is all the other mounting stuff is already on your frame.
You did not indicate if you wanted to go to mag wheels though. If you want to keep your spokes that is another animal.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
