Widening alloy swingarm?
- Fossil
06 Apr 2007 16:06
I need at least a few mm more width on the driveside of my swingarm just to centre a ZX9 wheel. If I could widen it just 1/4" overall it would make things a lot easier for both centering and mounting the caliper bracket. I spread a steel swingarm about 3/8" using a car jack, wondering if the alloy arm will spread 1/4" before cracking if pressure is applied/increased a little over a few days? I've seen a number of aluminum frames bent but not cracked at the wreckers, got me thinking.
Any ideas, suggestions?
- wireman
Re: Widening alloy swingarm?
06 Apr 2007 17:32
it would be really hard to keep things square without cracking it unless you were to heat it up a little,but that might weaken it also depending on what kind of aluminum it is.got a picture of the swingarm?
- Fossil
06 Apr 2007 17:41
wireman wrote:
The hub been machined as much as possible, so the only option now is to open up the swingarm a bit. Machining a few mm off the eccentric and trimming the swingarm would do it but I really don't want to remove material there, it would be removing a bit from the welded joint.
Here's the only pic I have showing the swingarm.
- reborn650
06 Apr 2007 17:41
Hey Fossil - If I were you I would take the swingarm to a good machine shop that works with specialty metals. They will tell you if it can be done without causing any stress cracks.
It doesn't cost anything to get an estimate and they might even give you some ideas on how to do it yourself. When it comes to an expensive part like a swingarm, I wouldn't take a chance on breaking it through experimentation.
-1998 Jeep TJ Wrangler 4.0 litre for the kids
-1975 Zamboni - The real Italian sportscar fully restored and functioning every winter at our local outdoor playground rink.
Mine is an ecclectic collection of motorized toys - LOL
I have a newspaper route and a web site where you can plan your own funeral life celebration www.mysendoff.com ....and go out with your own style.
- wireman
06 Apr 2007 18:50
do you have enough clearance everywhere besides the adjuster,or does the whole side need to be moved out?if you had access to a good heli arc and a welding table where you could clamp things down nice and square without moving it could be mitre cut in a couple spots and bent like a box ofset in a piece of conduit and welded back together i suppose;)
- Fossil
07 Apr 2007 21:25
Fossil wrote:
Problem solved - just bought a brand new ZZR1200 swingarm with axle, adjusters, pivot bolt and chain guard for $143 shipped - a "buy it now" on ebay. And, it's in Canada too so I might see it this week.
- Fossil
07 Apr 2007 21:28
pic and dimensions - very close to the GPz, similar linkage and wide enough for the 5.5" ZX9 wheel and 170 tire.
- wireman
07 Apr 2007 22:02
cool,thats cheaper than modifying your stock one!
