Offset front sprocket for the KZ750
  • schmol
  • schmol's Avatar Topic Author
04 Apr 2007 04:08
#126339
I know this has been brought up before, but has anyone ordered one for a KZ750? If you did, who did you order it from and what is the part number? I'm pretty sure it is the same as the KZ650.
  • steell
  • steell's Avatar
Re: Offset front sprocket for the KZ750
04 Apr 2007 04:33
#126341
Pre 81 KZ650 used a 530 sprocket, KZ750 four used a 630 sprocket.
83-85 GPz750 uses a 5mm offset 630 sprocket, so if 5mm is enough offset just get a GPz750 sprocket.
  • schmol
05 Apr 2007 15:22
#126797
Actually my bike is '82 GPZ750R1 and yes it did come with a 630 chain, but I swapped it out for a 530. My new rear '03 swingarm conversion and the factory front sprocket is about roughly 3/8" off to being aligned.
So the 5mm is not enough...
  • Fossil
  • Fossil's Avatar
05 Apr 2007 15:47
#126808
Here's a link to JT sprockets catalog/chart. By going through the Kawasaki sprockets and comparing the splines to those of your bike, you might find what you need.
Russ here suggested this to me and I was able to find a 24mm offset sprocket for my project and ordered it through a local Kawasaki dealer.
www.jtsprockets.com/58.0.html?sel_day=14...onth=9&sel_year=2005
