Front sproket problem
- sturm
03 Apr 2007 22:47
I need to change the oil seal behind front sproket, but i have a minor problem. I can´t get the sproket nut open:whistle:
Does it open clockwise or counter clockwise? There is no mention about it in repair manual.
And the bike is kz 1000 police ´80
-Matti-
-Matti-
Re: Front sproket problem
04 Apr 2007 00:57
Here's a recent thread about removing the countershaft sprocket nut. Additional links may be obtained by using the forum search box -- just type in countershaft sprocket nut and press enter on your keyboard.
Post edited by: Patton, at: 2007/04/04 03:59
- sturm
04 Apr 2007 23:09
Yes, i know how to use search, i might be new in this forum but not stupid
For some mysterious reason search is not an option for me, because it doesn´t work in my computer. it doesn´t matter what i write in search. i´ll allways get same ansver "Total 0 results found. Search for [ sproket ] with google"
I´just thought that someone has some trick in his sleeve for that nut. Because i´v tried everything(impact wrench, pipe, etc.), exept breaking it.
- 77KZ650
04 Apr 2007 23:31
maybe its because youre leaving out the c in sprocket when you search??
a big impact or breaker bar should take it off. little ones wont cut it.
07 MDP Rookie of the Year
- sturm
04 Apr 2007 23:51
I meant that it just the same what i write in the search field, it allways gives me the same ansver. Not found search with google. With or without the spelling errors.
Btw. i´m Finnish so there can be quite of few spelling/grammar errors. Please forgive me:lol:
05 Apr 2007 08:39
Patton wrote:
Just click on the words shown in red. It is a direct link.
The search function is suggested for those interested in additional links.
Let us know if search function problems persist and more direct links are desired to additional threads.
Good luck with the repairs.
countershaft sprocket nut <br><br>Post edited by: Patton, at: 2007/04/04 03:59
- KaZooCruiser
- KaZooCruiser
05 Apr 2007 09:17
Search
Search Keyword sprocket Search for: sprocket
Search Results: 2009 Hits
Re:Offset front sprocket for the KZ750 2007/04/04 07:33 In Topic Title
Offset front sprocket for the KZ750 2007/04/04 07:08 In Topic Title
Re:What sprockets & chain do you run? 2007/03/29 21:06 In Topic Title
Re:What sprockets & chain do you run? 2007/03/29 17:14 In Topic Title
What sprockets & chain do you run? 2007/03/29 16:44 In Topic Title
Post edited by: steell, at: 2007/04/05 13:30
List edited for brevity
KZR Moderator
- 77KZ650
05 Apr 2007 10:03
holy crap kazoo, that's quite a list. funny how lack of spaces turn some text into emoticons:laugh:
sturm, if you want, you could get the google toolbar and it will do spell checks for you if you tell it too. it may help you to get proper searches every now and then once you get the search function to work. even though we know what your saying, the computer might not;)
- steell
05 Apr 2007 10:34
I doubt that spelling is the problem, as I just did a search for "sproket" and it showed 130+ hits.
I rather suspect it is a software problem with his computer.
- sturm
05 Apr 2007 23:33
Steell. You finally got the point. I think that this piece of s... laptop doesn´t work properly.:blink:
But thank you any way.
