Moving right along...getting close
  • schmol
  • schmol's Avatar Topic Author
28 Mar 2007 18:59
#124450
Just finished getting my swingarm mounted and going to proceed onto the fabbing the mono mounts:
img.photobucket.com/albums/v220/schmol/HPIM0288.jpg
Post edited by: schmol, at: 2007/03/28 22:01
  • wireman
  • wireman's Avatar
Re: Moving right along...getting close
28 Mar 2007 19:27
#124465
cool!;)
  • z1rick
  • z1rick's Avatar
28 Mar 2007 21:00
#124495
Looks great, wish I had the resources to do that, Some day:whistle:
Anaheim CA
1999 KZ 100P
1974 Z1 900 Project
1977 (2) KZ 650 projects
  • AR15Ron
  • AR15Ron's Avatar
29 Mar 2007 01:26
#124517
That's awesome! Wish I could do something like that.
  • schmol
29 Mar 2007 04:02
#124524
Hasn't really taken all that much to do...it does help when you have a great friend that paints and does some fabbing for a living though.
  • AR15Ron
  • AR15Ron's Avatar
29 Mar 2007 04:14
#124525
I read some of the threads about going about swapping swing arms.. sounded terribly complicated! Anyway, I like the looks of the one you chose, it's prettier than a lot of the ones I've seen done. Do you know if it's possible to retain the stock wheel/sprocket setup with something like that?
  • schmol
29 Mar 2007 14:44
#124693
Ar15Ron, you probably could use the stock wheel, but you would have to use a ton of spacers to get it in the middle of the much wider swingarm. I used a '03 Kawi 636 swingarm/brake setup with a '97 ZX7R rear wheel and cush drive.
To get the swingarm to fit, we had to grind just a little bit off on either side of the frame where the swingarm axle goes thru.
I thought about having mounts tig welded onto the 636 swingarm so I could just use the factory style shock, but I went for the mono shock look.
  • AR15Ron
  • AR15Ron's Avatar
29 Mar 2007 21:43
#124809
I like it. Maybe next winter I'll make that my project :) It would be nice to get new wheels and fatter tire. Did you have to do anything in the front or did the new wheel bolt right on with the factory brake caliper and all?
Ron
  • schmol
31 Mar 2007 15:33
#125238
If you swap it out, you will have to update almost everything...
