master cylinder help....
  • Draco
  • Draco's Avatar Topic Author
19 Mar 2007 07:35
#121533
I am looking for a shorter front master cylinder than the stock one on my 80 KZ750E. I need the resevoir to be shorter lenght wise not height wise. I have dual disc brakes, so that needs to be taken into consideration too. Does anyone have any suggestions?
Thanks
  • OKC_Kent
  • OKC_Kent's Avatar
Re: master cylinder help....
19 Mar 2007 08:14
#121545
Do you want a shorter cylinder because you don't have room for the stock one? If that's the reason have you thought about a remote located cylinder design?
Cashion, OK
78 KZ650 B2 85,000+ miles
  • Draco
19 Mar 2007 08:24
#121547
the stock one will fit, but the brake line gets in the way of things.
  • H1Vindicator
  • H1Vindicator's Avatar
Re: ----
19 Mar 2007 09:35 - 21 Feb 2013 11:01
#121558
Last edit: 21 Feb 2013 11:01 by H1Vindicator.
