Clutch cable routing...??
- indykaw77
15 Mar 2007 18:00
OK....got rid of my clubman bars and installed superbike bars. Before clubmans, I dont remember this kink at the handlebar adjuster......
I'm almost dead certain I routed it all back as before....(I hadda take cable off cause I FORGOT to get it under the pipe and it was rubbing...DOH!!:pinch:)
The cable, as routed now....hits the gauge cluster no matter which way I route it.
Another pic....
Ideas? Pics of yours, maybe?? That kink has GOT to go.......:blink:
Kawasaki Motorcycles...because cars lean th wrong way!
- wireman
Re: Clutch cable routing...??
15 Mar 2007 20:07
those superbike bars are shorter than stock bars.id say either reroute your cable or maybe try some shorter cables,i think a z1r clutch cable is shorter;)
- barney
16 Mar 2007 04:31
Did you try going down through the centre of the triple tree? Its the way my cable is routed,doesn't bind and works fine.
- indykaw77
16 Mar 2007 04:56
barney wrote:
No....just thru or around headlite mount. But will give that a shot right after heart-start treatment.....a.k.a. coffee;)
