Monoshock susp w/stock swingarm...
- indykaw77
06 Dec 2005 12:10
Anybody ever tried/done this???? Sure dont seem to be much room in there. 'Course, some folks may ask "Why would ya??"
Just curious as to if anyone had given it a shot.....
on a 77 kz1000A.
(I just love them monoshock setups!)
on a 77 kz1000A.
Kawasaki Motorcycles...because cars lean th wrong way!
- ejshotgun
Re: Monoshock susp w/stock swingarm...
06 Dec 2005 14:22
Indykaw77 have you tried the archive section? I did a quick search and found some info on different models and I know in the past (at least I think I remember seeing it) I saw pics of a monoshock setup in here.
Eric
Eric
- indykaw77
06 Dec 2005 14:55
did a semi-quickie looksee.....will dig a li'l deeper....
- Kawbeach749
27 Dec 2005 16:25
go to archive, then chassis, then the top of the third page is a perfect pic.
- Snakebyte
04 Jan 2006 00:49
I dont think putting a mono shock on a swingarm designed for dual is a safe idea. What do you guys think? I think it puts more presure on the arm.
- twowheeledterror
- Visitor
04 Jan 2006 05:42
I think that technically it can be done.
But I think that theoretically it would be easier and safer just to swap to a swingarm made for monoshock use.
If you look at swingarms they are boxed. What I mean is, the arms, 99% of the time, are boxed aluminum. The reason for this is because the edges of the "box" add rigidity to the arm.
KZ stock arms are not boxed... nor are they really that rigid.
- wireman
- Visitor
04 Jan 2006 06:34
definately what two wheel says,by the time you brace a stock swingarm enough to make it work without twisting you will have an extra 20lbs of braces and gussets,even with twin shocks there is some flex in the stock swingarm!goodluck,happy wrenching!
