Turning Brake Disks on Kz
- reborn650
12 Mar 2007 15:15
Hey Gang - I am considering having a local automotive machine shop turn my disks on their cutting lathe to clean them up and get rid of the shallow grooves. I am talking only taking a few thousandths of an inch off to have the new pads sit better as well as clean up the appearance of the 3 disks on my 650 custom.
I know they used to do this years ago with auto brake disks but most places simply replace the disks these days.
Any advice on having this done from fellow members that have had it done?
-1998 Jeep TJ Wrangler 4.0 litre for the kids
-1975 Zamboni - The real Italian sportscar fully restored and functioning every winter at our local outdoor playground rink.
Mine is an ecclectic collection of motorized toys - LOL
I have a newspaper route and a web site where you can plan your own funeral life celebration www.mysendoff.com ....and go out with your own style.
- sheik*yerbouti
Re: Turning Brake Disks on Kz
12 Mar 2007 15:26
dropped my three discs off at a tranny / driveshaft shop two weeks ago. i know a guy that works there, he stared at my rotors for a while and said "i've got just the machine."
he's going to use a machine that they use to turn flywheel and clutch stuff for big trucks and semis.
the cutting wheel looks like a wire cup brush, the kind that chucks in your drill, but obviously it's a lot bigger, impregnated with diamond chips, and rigidly mounted on a machine arm and it faces down toward a turntable for the workpiece.
he said he thought it would come out looking good as new. they said they will take as little material as possible to remove all the grooves and it should produce a new appearance.
will post up pics when they return!
- BSKZ650
12 Mar 2007 16:38
a standard drum and rotor machine will not cut a bikes rotor, the best thing is to grind them, but you need to make sure they can be kept flat, also check the thickness to make sure you dont get them too thin
77 ltd1000, current rider
76 kz900, just waiting
- 77KZ650
12 Mar 2007 17:37
I think both sides of the rotor have to be ground at the same time to prevent warping. Its been awhile since I read the article in the filebase about the dual disc upgrade
07 MDP Rookie of the Year
- wireman
12 Mar 2007 18:13
sheik*yerbouti wrote:
thats exactly what i was gonna suggest;)dropped my three discs off at a tranny / driveshaft shop two weeks ago. i know a guy that works there, he stared at my rotors for a while and said "i've got just the machine."
- oldcoldankles
12 Mar 2007 18:45
I agree also. My rotors were resurfaced at an engine machine shop on a flywheel refacer, instead of a brake lathe making sure the thickness stays uniform. It takes off only a few thou, leaving a nicer finish without chattering, eliminates the phonograph record groove effect, takes out the hard spots better, and gives you really smoooooooth braking for about $20 - $30 a rotor. The minimum rotor thickness will be found in your service manual. Worked great on my Corvette too. Best of luck to you.
Peachland BC
1981 KZ1000 CSR M1
1983 KZ550 LTD M1 (Shaft)
1989 Corvette coupe
1981 KZ1000 CSR M1
1989 Corvette coupe
- austin3119
12 Mar 2007 19:09
Good topic. I have been wondering for a while what I could do about the "record look" on my front rotor. Thanks for the info.
- 77KZ
12 Mar 2007 20:13
Why waste the time when you can just pick up a cheap one like this:
Cheap disk on eBay
What a sweet deal!:laugh: Actually there was a place on e-bay that was advertising rotor grinding for $35 each I believe. Problem would be shipping charges! Let us know what you find I need a few done.
Post edited by: steell, at: 2007/03/12 23:27
Cheap disk on eBay
"What do you mean we can't change the alphabet to W,X,Y,K,Z!"
Western, OH, Formerly... Western, NY
1978 KZ650B, 1979 KZ650C, 1978 KZ750B, 1982 KZ750 LTD, 2006 ZX-6R, 2009 Ural Gear Up, 1974 Yamaha DT360 (It's Green Anyway!)
- sheik*yerbouti
12 Mar 2007 21:31
holy crap, almost five hundo shipped for *one* rotor.
thank you allpro transmission shop! $50 to surface all three...
- KZQ
- Administrator
12 Mar 2007 22:13
This guy on E-Bay will grind your disk for $43.00 including shipping. He's got over 1100 feed backs with 100%. I just sent my rear disk from an 85 1300 off to him. I did it despite knowing that it's way too grooved. Be interesting to see how he handles it.
Check him out. Search for "smw70ss" on E-Bay
KZCSI
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- z1rick
12 Mar 2007 22:18
Here is a link to one of his auctions...
tinyurl.com/2hydz5
tinyurl.com/2hydz5
Anaheim CA
1999 KZ 100P
1974 Z1 900 Project
1977 (2) KZ 650 projects
1999 KZ 100P
1974 Z1 900 Project
- sheik*yerbouti
12 Mar 2007 23:08
Holy schnikes if mine look anything close to that I'll be ecstatic! Sounds more like the machine my shop is going to use, not a brake lathe but a rotary surface grinder...
Post edited by: sheik*yerbouti, at: 2007/03/13 02:09
