extended monoshock swingarm
  • scratch312
  • scratch312's Avatar Topic Author
11 Mar 2007 19:44
#119332
I just purchased a 1980 KZ ltd 1000. this is my first street bike, and it hopefully will be heavily modified. My first order of business is to swap the stock swing arm with an extended monoshock swingarm. I've seen it done, so I know it's possible, but I'm having a hard time finding any info on what parts are compatible, and how much of a headache making the jump to monoshock will be, as far as connecting the rear shock onto the frame. I also dont know how expensive this modification will be. I don't nessesarily want a huge strech, just a few inches longer than stock. If anyone has any advice, it will be GREATLY appreciated. Thanks!!!
  • wireman
  • wireman's Avatar
Re: extended monoshock swingarm
11 Mar 2007 19:52
#119338
check solomrus's yet another zed post;)
  • 77KZ650
  • 77KZ650's Avatar
11 Mar 2007 19:57
#119341
first off, welcome to the forum
most new mono shock swingarms are a bit longer anyway. the 636 arm on my bike is about 3-4 inches longer than a 650 arm, so about 2-3 inches longer than yours, if you want longer, there are bolt on swingarm extensions or have a competent welder/fabricator to make it longer. Muzzys does this for example. if you can weld steel, you can make the shock mounts , so just buy some steel tubing and your pretty much set for the big stuff
07 MDP Rookie of the Year
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
12 Mar 2007 12:50
#119527
Squatch has photos on his web site ,he sells air clutches.Try to google it or maybee some one here will help,I dont have the site on this computer right now.I'll try to get back with it latter.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • JAILBAIT
  • JAILBAIT's Avatar
15 Mar 2007 10:53
#120413
Well to answer your question real easy, its gonna take a lot of fab work and time. First you will have to have all parts on hand. shock swingarm wheel and tire combo. This way you first setup for ride hight. You need to know the sag of the spring with the weght of the bike and then the weight with you on it. Then you will have to crossbar the frame and put in supports all around the frame. see the thread on bobbing the frame. Then you will have to weld the cross bar in and weld tabs to your swingarm to support the shock. This is obviously just a few things to take into consideration. It is most likely going to take a lot of fabbing to get it set up right and not be a rolling death trap.
  • z1rick
  • z1rick's Avatar
15 Mar 2007 20:25
#120577
Here is a link to the post
Wireman mentioned:
Lots of good info...
Post edited by: steell, at: 2007/03/16 09:04
Anaheim CA
1999 KZ 100P
1974 Z1 900 Project
1977 (2) KZ 650 projects
  • z1rick
  • z1rick's Avatar
15 Mar 2007 20:35
#120578
And here is a link to Squatch airclutch project bikes...
www.squatchairclutchsystems.com/gallery/index2.html
Anaheim CA
1999 KZ 100P
1974 Z1 900 Project
