need help with my swingarm project
- badboie
10 Mar 2007 02:38
I've got a 1981 KZ750 LTD. I'm looking at this 2005-06 KAWASAKI 636 ZX6 REAL WHEEL WITH SHOCK/SWINGARM setup that I can buy and I was wondering if anyone knows the specs or dimensions of this swing arm so I can do a check to see what all I will need to do in order to make this swing arm work at all. I may not be able to but I would like some help if anyone could offer some. Thanks for anyones help.
- badboie
- badboie
Re: need help with my swingarm project
11 Mar 2007 09:20
well I put an order on it so I'm just gonna wing it because nobody offered anyhelp... thanks.
- steell
11 Mar 2007 17:39
badboie wrote:
You are asking for pretty specific info, and there is a real possibility that no one here has done what you are attempting to do.
Maybe you get to be the first
- indykaw77
11 Mar 2007 18:13
steell raises a good point.....I doubt anyone has dimensions or "specs" at their disposal for this particular arm.
That being said....there are ALOT of projects here that folks have come up with that few, if ANY other members have thought of or attempted, let alone been able to offer help with. With this swap you're doing, you will have a chance perhaps in the future to offer advise/tips.....or warn everyone off if it CANNOT be done.
The projects forum and the archives are great places to research this particular endeavor (swingarm/monoshock conversion). Be advised that spacers may need fabbed up for pivot area.....upper shock mount welded in...offset sprocket might be needed.....hell the list is endless. Thats part of the fun....learning and perhaps sharing the experience. I, for one, wish you luck and hope to see progress pics and reports as you go.
Kawasaki Motorcycles...because cars lean th wrong way!
- 77KZ650
11 Mar 2007 19:47
OK, calm down, some ppl dont log in every day, and sometimes they dont look at everything new, give it a few before you get mad.
I had to narrow the swingarm I have on my 650 to get it to fit, I assume you will have to do the same. you need to make shock mounts too. and theres other stuff to be sorted out, but thts the fun part of fabricating custom stuff;)
07 MDP Rookie of the Year
- badboie
11 Mar 2007 21:16
no no no, ok so what I was asking is if anyone knew the spec of the KZ swingarm, not the swing arm I am getting. I'm guessing that there has to be someone on here that has that info since there are many different swingarm projects that have or is being done. I already know the specs of the swingarm that I've placed an order on. I look back and I see that I messed up with what I asked so I'm sorry for the confusion. I ment the KZ's swing arm. :blush: :pinch:
