replacement forks (KZ440) a little longer the the KZ400 - ?
  • primemover
  • primemover's Avatar Topic Author
09 Mar 2007 15:13
#118745
Hi All...
i posted a few days back (and a couple of times) about my bent forks on a 1978 KZ400...
i got my hands on a set of forks from a KZ440 (not sure of the year)...
took a little doing, but was able to get them apart (the top cap one one was rusted!!!)...
well, the inner tubes of the KZ440 forks are ~3.5 cm
longer then the ones (bent ones) i'm replacing...
a part of me thinks that this should not be a MAJOR problem.... though it will certainly through off the weight distribution of the bike (i.e., front end higher = more weight on back???)...... ???
also, wonder if i could simply install the forks so they sit ~3.5 cms higher inside the steering heads....
anyway,...
thoughts...
suggestions...
advice???
punishments for having these thoughts???
thanks...
- prime
  • flht1997
  • flht1997's Avatar
Re: replacement forks (KZ440) a little longer the the KZ400 - ?
09 Mar 2007 15:39
#118753
i say OK. don't really see a problem. i lowered all my 400's by sliding the tubes up till they hit the handlebars.
heck lets put a picture
Post edited by: flht1997, at: 2007/03/09 18:46
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
  • flht1997
  • flht1997's Avatar
09 Mar 2007 15:48
#118758
come on picture...
Matt Milwaukee, WI
89' BMW R100RT
06' KLR650
  • primemover
09 Mar 2007 16:24
#118771
great!
i keep hitting road blocks with this fork issue...
glad i can dela with this one...
i have another problem, but will post in a few days...
"baby steps"...
thanks!
  • primemover
09 Mar 2007 16:27
#118773
OH!
curious....
my plan is to use the inner pipes from the KZ440 (replacement part) and the lower pipes (which i had previous cleaned up/painted OH SO NICE!) from the KZ400...
i have not yet done a direction comparison, but on the surface, everything seems the same...
if the springs from the KZ440 are longer than the springs from the KZ400 (the bike i'm restoring), i assume i should use the KZ440 springs (i.e., they would properly "fill" the tube), right?
  • flht1997
  • flht1997's Avatar
09 Mar 2007 17:12
#118785
yea, i'd think if you are using the longer tubes, use the longer springs.
Matt Milwaukee, WI
89' BMW R100RT
06' KLR650
