Question- swapping side covers?
- OKC_Kent
09 Mar 2007 09:14
Does anyone have any knowledge in this area of body parts on KZ's?
I've tried using the Kawasaki site and Zedder software to determine if any other covers will fit the 83 750 LTD I have. It makes it tough to know what will fit the bike because the parts are coded by color, so a cover may fit but you can't really tell,,,,everything tells me I have one of a kind covers, and I really doubt it, something else must fit the stud pattern and general shape.
Anyone know?
Anyone know?
Cashion, OK
78 KZ650 B2 85,000+ miles
- kano
- Not Another Bloody Limey!
Re: Question- swapping side covers?
09 Mar 2007 10:09
post some pics of both sides
and post pin to pin measurements
so we have a reference to go too
ill measure my side panels to compare against.
- H1Vindicator
Last edit: 21 Feb 2013 02:26 by H1Vindicator.
- OKC_Kent
09 Mar 2007 14:04
H1Vindicator wrote:
I checked buykawasaki and the Spectre frames are an exact match to the LTD Shaft, so the cover holes are the same and the covers should fit. Unless the seat gets in the way somehow... I'll check that too. Thanks H1Vindicator!
This is just speculation, but the 750-Spectre covers look real close.
And if it's any help, the 80-83 KZ750-E-Stnd, 80-83 KZ750-H-Ltd & 81-83 KZ650-CSR use the same side covers (the emblem holes are spaced the same on all of 'em too), so you can probably rule out all of those bikes. JMK.
Cashion, OK
