Triple Clamp Specs
  • Kellen79_650
  • Kellen79_650's Avatar Topic Author
Triple Clamp Specs
06 Mar 2007 20:39
#117937
OK guys, I know that one of you out there has the technical knowledge to answer this question, so here goes; I want to get a new top triple clamp machined but I don't trust myself to accurately measure the triangle formed by the center of left fork, center of right fork and center of steering stem. Any of you have an insight or your own numbers that I can compare mine against? As long as I have those numbers and I get a nice little design going.
Thanks
"In the beginning of a change, the Patriot is a scarce man, Brave, Hated and Scorned. When his cause succeeds however, the timid join him, for then it costs NOTHING to be a Patriot."
~Mark Twain
  • pstrbrc
  • pstrbrc's Avatar
  • '81 GPz 1100 project
Re: Triple Clamp Specs
06 Mar 2007 20:53
#117951
What is your true steering head angle?
What size front tire are you going to use? (both diameter and width.)
What trail are you aiming for?
How far apart do your forks need to be?
Here's a pic to help you understand what you're looking at:
\'81 GPz 1100 project
Elkhart, Kansas USA
\"Man does not control his own fate. The women in his life do that for him.\" Groucho Marx
  • Kellen79_650
06 Mar 2007 21:07
#117955
Well, I am working with a 79 kz650 and am only replacing the top clamp so the width, angle and all that are stock.
~Mark Twain
  • Fossil
  • Fossil's Avatar
06 Mar 2007 22:48
#117977
Unless I'm missing something, why not give the machine shop the stock top triple clamp and have them use that to replicate the center to center distances, offset, correct "hole" sizes and let them see how the pinch bolts should work and generally give them an idea what you want to replace.
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
07 Mar 2007 05:45
#118012
I uploaded a file named MotoGeo.txt to the filebase. It's a motorcycle geometry calculator. You'll need to change the file extension from txt to exe. Not to worry it's no threat. Once you rename it just double click to run.
I never really needed it but I learned a bunch about chassis design while playing with it.
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • Kellen79_650
07 Mar 2007 16:15
#118187
Well, that is an option, but time is money and the less time they spend on it the more money I save, plus I just like doing what I can myself
~Mark Twain
