Where to purchase brake lines
- Oznative
26 Feb 2007 09:14
I know this subject probably has been beaten to death but I need advice.
I need new brake lines on my 1977 KZ1000 A-1. It has duel front calipers so I need 3 lines for the front and 1 for the rear. The front lines from the splitter to the calipers have the banjo on one end and the female coupling on the other to fit the hard piped line attached to the caliper. Where can I buy direct replacement lines? I’ve looked at Z1 and they don’t list for duel fronts.
Any suggestions?
Any suggestions?
1977 KZ1000 A-1 Just north of Boston
- OKC_Kent
Re: Where to purchase brake lines
26 Feb 2007 11:28
You might try Dennis Kirk, BikeBandit, American Classic.
Cashion, OK
78 KZ650 B2 85,000+ miles
- N0NB
- Blue handles better
26 Feb 2007 13:07
I just got the set I ordered from
www.helusa.com
late last Thursday. They are stainless steel braid with a non-scratching outer coating available in the color of your choice (I chose black). The banjo ends and bolts are also stainless steel and the kit comes with new crush washers and stainless steel bolts.
My three-line kit came to $147. Last year I did a price comparison with the build-yer-own parts comparable to the HEL kit, and the HEL lines were only about $5 more without the uncertainty of an incorrectly assembled fitting that will let go when needed most.
Just call Craig with the measurements from your original lines and the positioning and angle of the banjos. Other approaches may seem cheaper, but after pricing everything I chose HEL lines and I'm satisfied with them.
As I see it, brakes are no place to "save" money.
- Nate >>
- Nate >>
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel
- H1Vindicator
Last edit: 21 Feb 2013 21:29 by H1Vindicator.
- indykaw77
26 Feb 2007 18:10
You can check here as well:
www.mgcycle.com/brakelines.html
Scroll down a bit....you'll see the lines by the foot and all the fittings and such.
Kawasaki Motorcycles...because cars lean th wrong way!
- Oznative
27 Feb 2007 03:39
Thanks to all who responded. On the front brakes with the duel lines do they come with the screw on fittings that attach to the hard pipe?
- CoreyClough
- GPz550 Addiction
27 Feb 2007 04:34
...or you could do what I did, and buy a parts bike that has them already! :woohoo:
'85 GPz550(ZX550-A2)
- wiredgeorge
27 Feb 2007 04:49
Most of the larger bike catalog stores sell universal brake lines. I have used Goodridge lines in the past with good result. Denniskirk.com and jpcycles.com both sells this type brake line. They carry lines in almost every length. These lines have screw in fittings and they also sell a variety of banjo fittings. You buy the 10mm fittings and screw them into the line using new crush washers. The fittings come in various configurations... straight, 45 degree, 90 degree, etc. The lines are pretty reasonable and will last forever. If you do get stainless braided lines, make sure you spend a couple bucks more and get the plastic clad stainless as regular stainless with scrape off paint.
- Oznative
27 Feb 2007 07:51
Thanks guys I really appreciate the info. This is the first bike I've ever done and to be honest It's much more difficult than I thought. A 30 year old bike is hard to find those little parts.
