Shaft drive leak
  • geerbangr
  • geerbangr's Avatar Topic Author
Shaft drive leak
21 Feb 2007 15:12
#114236
WTF causes the final drive to leak gear oil when the bike is setting in my garage on the centerstand ??? I had the ass end of the bike apart because I had to pull the swing arm to work on the front bevel gear when I put the bike back together it's dripping gear oil now .
1978 KZ 1000
I go by Jason
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
Re: Shaft drive leak
21 Feb 2007 17:09
#114257
I've heard of this several times. It's the front seal leaking and the oil's running through the swingarm to the back end and dripping from the drain. Are you sure it's gear oil? What does it smell like?
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • geerbangr
21 Feb 2007 19:43
#114297
It's most definetely gear oil
1978 KZ 1000
I go by Jason
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
21 Feb 2007 21:15
#114334
Well, of course there are two seals on the pumpkin. They can go out.
If you've been hearing any increased whining coming from the rear end it's likely caused by a worn pinion bearing which lets the pinion move enough to ruin the seal.
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
