Nuts and bolts...
- KzJim
Nuts and bolts...
21 Feb 2007 10:28
Anyone know the thread size for the lock nut for the stem and the bolt for the top yoke for a 76 900?
Naiveté in grownups is often charming, but when coupled with vanity, it is indistinguishable from stupidity.
Tis better to remain silent and thought a fool - than to speak up and remove all doubt.
Did ever think that maybe you've been doing it wrong all these years?
- Mcdroid
- Gone Kwackers
Re: Nuts and bolts...
21 Feb 2007 11:14
I have a KZ1000A1 front end apart right now and I believe it is the same as the KZ900A4/5. If no one posts, I'll measure and post when I get home tonight.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- Mcdroid
- Gone Kwackers
22 Feb 2007 05:35
I assume you are asking about the size of the threaded portion of the lower triple tree? It is 30mm...if I'm not getting your request, PM me with the lurid details.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- KzJim
22 Feb 2007 06:59
Yup.. that one that i needed, i also need the bolt that locks the upper yoke to the stem.
- Mcdroid
- Gone Kwackers
22 Feb 2007 13:09
KzJim:
The big bolt that screws into the top of the stem (and holds the top of the triple tree on) is a 16mm bolt.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- KzJim
22 Feb 2007 16:01
Thanks.. I went out today and bought me a metric thead gauge... the 30mm lock-ring is a 1.0 pitch and the 16mm bolt is 1.5 Just and FYI...
...and here is a link to metric drill and tap sizes
Post edited by: KzJim, at: 2007/02/22 19:14
- KzJim
23 Feb 2007 07:32
Mcdroid.... you wouldnt be putting a taperbearing kit in that 1000 would you?.. if so.. can i get the bearing manufacture and P/N? I'd like to ger the bearing race ID tolerances from the manufacture so i can make sure it all fits together
I reverse engineered the stock KZ900 stem with modifications to replace the zx7 stem.
- Mcdroid
- Gone Kwackers
23 Feb 2007 07:46
Yes, I will be...and I haven't purchased the kit yet, but I will be buying from the guy below...
www.ty-coon.com/categories.asp?cat=146
That is, if he eventually stocks them as he as indicated...if he doesn't in a reasonable period of time, then it will be www.Z1Enterprises.com as usual:)
Post edited by: Mcdroid, at: 2007/02/23 10:49
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- KzJim
26 Feb 2007 12:07
McD.. can you post the ID measurments for the head tube, both top and bottom?.. thanks
- Mcdroid
- Gone Kwackers
26 Feb 2007 12:29
Will do...it will be after dinner before I get into the garage, though:)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
