Rear Master Re-build, KZ650
  • drayman86
  • drayman86's Avatar Topic Author
21 Feb 2007 05:56
#114085
OK, so I've got a source for the piston on the rear master which appears to be the critical replacement part. Has anyone ever taken these rear masters down to the point that they can get the spring and primary cup (parts 7 and 8 below) out? What is the function/purpose of bolt 6? is it necessary to remove bolt 6 to replace the spring and primary cup? Thanks!
Post edited by: drayman86, at: 2007/02/21 08:59
  • drayman86
Re: Rear Master Re-build, KZ650
21 Feb 2007 06:18
#114093
Here's the schematic
  • drayman86
22 Feb 2007 15:12
#114532
Bump. Someone's gotta have experience with these rear masters. Can Jeff Saunders help?
  • drayman86
26 Feb 2007 03:46
#115472
At the risk of being a pest, maybe I can suggest another route for assistance.
Does anyone out there have the factory service manual for my 1978 KZ650 C2? If so, I'd appreciate contact through a PM to discuss the procedure for disassembling this rear master cyl.
Thanks to the more than 80 views of this thread. Somone's GOTTA know what's up with this rear master. :(
  • hardr0ck68
  • hardr0ck68's Avatar
  • Who put the what in the where?
26 Feb 2007 04:00
#115473
now i took mine apart sometime ago, and i have little to no clue how it goes back together, but as i recall you have to pull clip 11 (which i couldent see hidden under gunk) and everything comes apart.
i know i did it, i know all the rubber bits in mine were gone, and the paint was ruined...but i never found a rebuild kit and have kinda forgotten about it while i think about making it move on its own (otherwise who needs brakes?)
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
  • wireman
  • wireman's Avatar
26 Feb 2007 05:28
#115496
looks the same as 77-78 kz1000 rear mastercylinder to me,clip 11 needsto come out;)
  • drayman86
26 Feb 2007 11:26
#115582
Thanks for the reply guys.
Should've been clearer in my original post. :blush:
I have removed Clip 11, which results in the piston (#9) falling out. HOWEVER, parts # 7 & 8 still remain, i.e. they don't come sliding out. I'm afraid to start poking and prodding for fear of damage and if I DO decide to replace them (they are available, as are many of the parts for this master), I'm wondering how to do it.
This is why I asked about bolt #6.
I may be getting too far ahead of myself, but brakes is where I am in this project.
Thanks.
26 Feb 2007 15:31
#115632
drayman86 wrote:
...I have removed Clip 11, which results in the piston (#9) falling out. HOWEVER, parts # 7 & 8 still remain, i.e. they don't come sliding out. I'm afraid to start poking and prodding for fear of damage and if I DO decide to replace them (they are available, as are many of the parts for this master), I'm wondering how to do it. This is why I asked about bolt #6.
A little air pressure through hole where banjo fits should blow out the primary cup and the spring should drop out behind it.:)
The following user(s) said Thank You: GPz550D1, jeffwerner
  • drayman86
26 Feb 2007 19:31
#115690
Right, thanks! I'll give that a shot. Always a bit leery just pulling things apart....:blink:
