Tire Sizes
- EsaPro
Tire Sizes
14 Feb 2007 17:30
Since I have my rear end apart, I thought I might change out the chen-shin 120/90-18 rear tire (Front is a new-enough-to-still-have-the-nubbies Dunlop K70).
Now, seeing that the rear is not the true stock size (4.00H-18) and noticing that the chain guard looks to have been rubbing, I have the following questions for those who may have been down this road before me:
Would a 110/90-18 be closer to the original 4.00H-18?
Is it worth the trouble finding a 4.00H-18? I have found a few, but it severely limits one's choices, though it looks like Metzler has just such an animal for under $100.
It is a crime worthy of my physical punishment (when the bike self-implodes) to run different manufacture tires front & rear?
I would rather not swap the front, as it is practically new.
Jim
79 KZ750 Twin (Fun!)
07 Yamaha 1300 (Plush!)
- steell
Re: Tire Sizes
14 Feb 2007 22:56
Congratulations, you just stumped me with a KZ750 twin question :ohmy:
All my 750 twins have 16" rear wheels (Morris Mags or 80 G model drum brake mags), so I don't have a clue about 18" rear wheels on the 750 twin.
- EsaPro
Re: Tire Sizes
15 Feb 2007 17:05
Really? :ohmy: The FSM says:
Front: 3.25H-19 4PR
Rear: 4.00H-18 4PR
I have noticed that most of the wheels out on ebay for KZ's, including twins, are 16in. But the book (Covers 76-79) states 18in. I never thought much about it till just now, since it matches what's on the bike.
Let's see if I can go two-for-two. I have grokked what the 3.25 and the 4.00 are (Width). The "H" is speed rating, and the 18 & 19 are rim sizes. What is the "4PR" bit about?
Front: 3.25H-19 4PR
Rear: 4.00H-18 4PR
Jim
- pstrbrc
- '81 GPz 1100 project
Re: Tire Sizes
15 Feb 2007 17:43
Four ply rated?
\'81 GPz 1100 project
Elkhart, Kansas USA
\"Man does not control his own fate. The women in his life do that for him.\" Groucho Marx
Elkhart, Kansas USA
- steell
Re: Tire Sizes
15 Feb 2007 18:36
Complete tire info explanation, along with conversion chart
76-79 KZ750 twins were originally equipped with 18" rear and 19" front, there was a Dealer installed Morris Mag option that was 16" rear and 19" front.
I used the brake pedal and swing arm from a 1980 KZ750 G to install the 750 G's mag wheels on my 79, the 79 swingarm is on one of my 80 G models that is getting the Morris Mags. My 750 twins are all confused
Oh yeah, in answer to your original question, the above link says a 4.00x18 is the same size as a 110/90/18
Post edited by: steell, at: 2007/02/15 21:38
- RonKZ650
Re: Tire Sizes
15 Feb 2007 18:43
Don't know about the 18" vs 16" thing, but a 110 is closer to a 400-18 for sure. I went from a 120/90-18 to a 110/90-18 because I wanted back to original size tires. Every brand is different is the major problem though. I used to run 130/90-18 Pirelly (however it's spelled), and they were smaller diameter as well as less wide than a 120/90-18 Dunlop K591. Last tire I got was a Dunlop 404 I think, which is a pretty cheap tire and the 110/90-18 is really small in that brand. I wish there was more uniform across the board sizes among the brands. I went to buy tires for my truck and a 235/85-16 is just that. Every brand nearly identical for the most part, but not on motorcycles.
- EsaPro
Re: Tire Sizes
15 Feb 2007 20:02
Thanks for the link steell, that is what I needed!
Interesting that various manufactures are different physical sizes for the same "size" (geez,that just does not read well...). I looked online at Bridgestones Bt45's, since the manual calls for Bridgestone Super Speed 21's (not made anymore), then Dunlop D404, Michelin M50, Continental K112, and Metzler Lazertechs. Now I wonder about actual size.
Crikey, why make it so difficult? Might as well stamp them "Approximately" whatever size...
I may just putt it down to the bike shop once I get her together, and have 'em put on what they got handy...:blush:
Jim
- gpzrox
Re: Tire Sizes
15 Feb 2007 21:16
EsaPro wrote:
Careful: you don't want a radial tire back there, not with a bias front. I think at least a couple there are.
I'd go Dunlop bias ply, even though I run Pirelli. Ron named a couple of different Dunlop #s that should work.
84 GPZ750. Modded with stock Kawasaki parts: ZR-7 shock, ZX-6 coils, GPZ1100 throttle, EN454 brake, GPZ900 fuse box, etc. and non stock: Ken Sears mirrors, K&N filter, Pirelli Sport Demons.
- steell
Re: Tire Sizes
16 Feb 2007 04:54
Most of the manufacturer's websites have the actual width and diameters listed for each model of tire they make.
The following user(s) said Thank You: tdogm6@yahoo.com
