Z1 rear axle size
- dutchz
Z1 rear axle size
11 Feb 2007 17:05
Hey guys, quick question: what's the diameter of a Z1 rear axle? I haven't had the opportunity to pull it out this weekend and I gotta order some bearings tomorrow. Anyone know (for sure) or have a spare axle they can reach with their calipers?
1974 Kawasaki Z1
Stock front hub and rear axle.
- steell
Re: Z1 rear axle size
11 Feb 2007 17:21
About halfway down
This page in the Filebase
under the KZ Information tab at the top of any forum page is a wheel bearing list.
According to that list the Z1 uses two 6304-2RS wheel bearings, and the 4 in 6304 indicates it fits a 20 mm axle.
- Prune1
11 Feb 2007 17:23
Z1 Enterprises Link
....and this is quite helpful also!
Link to forum post of the wheel bearing list
Post edited by: steell, at: 2007/02/11 20:33
- z1kzonly
11 Feb 2007 20:29
20MM! .78740 INCH Z1 AND KZ900 KZ 1000.
- dutchz
11 Feb 2007 22:52
Mille grazie. Workin on a project
1974 Kawasaki Z1
- bigred
Re: 73 Z1-900
12 Feb 2007 18:53
I just found this web site and maybe You or someone can help me:( On Sept 28 a tractor-trailer cut me off going to work and I hit him doing 65mph on my Z1-900. I just got done rebulding the engine in her, 30-over and all new vavles and that. it only has 2134 miles on that motor,the full-coverage ins. wasn't received there untill two days after the wreck so they won't pay and the driver of the rig took off when he saw me on the ground.At 4:30 in the mourning there isn't to many people on the road so there was no-one to go after him! Here in Joplin MO and in this area I haven't found a frame that will fit?plus all the bills got behide because I don't go back to work for a week. And the wife doesn't want me spend alot to fix it. so is it pos. to just cut the fram tubes and replace them and the front forks/it just bent them up and back but didn't touch the engine WHAT TO DO???!!!! bigred
- wireman
- steell
Re: 73 Z1-900
12 Feb 2007 19:49
If you remember the name on the side of the truck, there is a possibility that you could hire a lawyer and he could subpoena the records of the company and identify the driver. Many companies use satellite tracking now.
- dnyce
Re: 73 Z1-900
13 Feb 2007 17:31
forks off ebay are pretty cheap, ive seen em go for 10bucks, triple tree and all. id say its safer to get another frame unless you have a chassis jig and you're a super awesome kick ass welder. frames arent too expensive, 50-250 on ebay.
