spray on chain lube removal
- arobsum
11 Feb 2007 11:50
i have got this stuff on my rear spokes and cannot seem to get it off. help!! what do you guys use to get your spokes looking good again?
- wireman
Re: spray on chain lube removal
11 Feb 2007 12:01
409 and a carwash house usually does the trick for me;)
- Bad Kaw
- Flying Squirell
11 Feb 2007 12:05
If it's that pasty sticky (like nearly dry gum) stuff take a rag and carb cleaner to it. The carb cleaner is some aggressive stuff so as soon as you get the wheel cleaned a good washing should follow. my .02.
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
70 Kawasaki KV75
- RetroRiceRocketRider
11 Feb 2007 12:28
arobsum wrote:
Wellllll, you could go with a simple 2500 psi model.
Or go balls-out and spring for the 3750 psi model to get that stuff that just won't budge for anything! :woohoo: :whistle:
Actually, I've found that Simple Green works pretty well, is touted as being bio-degradable, and won't trash what you're using it on like some harsher cleaner/degreasers might do.
Post edited by: RetroRiceRocketRider, at: 2007/02/11 15:31
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
- arobsum
11 Feb 2007 12:55
thanks!! it is that really sticky stuff, and dish soap won't cut it! i'll try the rag/carb cleaner method and see how it turns out!
11 Feb 2007 13:06
WD40 is a pretty decent chain gunge cleaner.
- RonKZ650
11 Feb 2007 15:51
You can eliminate this problem in the future by not using crap chain lubes that goober up everything. PJ1, Calgard, Chainwax, ect, ect.
- arobsum
11 Feb 2007 16:06
RonKZ650 wrote:
i believe it was pj1...what is a better alternative? gear oil?You can eliminate this problem in the future by not using crap chain lubes that goober up everything. PJ1, Calgard, Chainwax, ect, ect.
- kzwolfsr
11 Feb 2007 16:13
I have my own alternative, I use ATF. Plus you might not think it but ATF can clean your rims also, just as good as carb cleaner and once you leave it on the gummed up area it will soak in and remove all gum. I had pics of my chain on here. Gear oil will only put you in more probs, it attracts dirt
Original man of the Caribbean
- arobsum
11 Feb 2007 16:38
atf huh? i could try that...it cannot be any worse than whats on there now!!
- H1Vindicator
Last edit: 21 Feb 2013 21:17 by H1Vindicator.
- KZDon
12 Feb 2007 11:27
I've been using a little WD40 on a cloth. It seems to get the worst goop off. I've also had some luck with degreasers like 409 or Simple Green.
Then, I had (brief) flash of brilliance. I used some car wax on the areas of the rim usually worst covered with goo to prevent the stuff from sticking in the first place, and... it worked reasonably well. It's too bad I never get around to waxing the rims regularly.
Midland, Ontario, Great White North
2004 650 V-Strom
farewell to 81 KZ550A2 - 82 GS750T - 83 GPz750 - R-Reg GT380 - 76 DT175 - 84 GPz550
2004 650 V-Strom
