79 KZ650SR Brake rotors ???
- Tower_Monkey1
30 Nov 2005 17:23
Has anyone put 79 KZ650SR rotors on a 78 KZ650C2 as a upgrade ? Im looking at getting a set of front and a rear drilled rotors for my 78 650C2 and was wondering if they will fit with the stock calipers ? If anyone knows please let me know... Thanks Wayne
78 KZ650C2 Dyna ignition and coils,Pod filters,4-1 Kerker,CBR Tail Light,Drilled front dics,Custom front fender,1/4 fairing.
- rstnick
Re: 79 KZ650SR Brake rotors ???
30 Nov 2005 17:50
The front rotors should be no problem, but the rear may be a different spec as the caliper is different.
You could always drill yours if they still have some life in them. I had mine done years ago as I found my brakes su*#ed in the rain.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- rstnick
30 Nov 2005 17:54
I may have a set from my '79 C3 (factory drilled) in my workshop. I know the rear is just about toast, worn to the minimum specs because of the Sintered Pads. I could check to see if I have the front 2 if your interested? I may have sold them, but I somewhat remember seeing them not long ago.
Post edited by: rstnick, at: 2005/11/30 20:54
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- Tower_Monkey1
01 Dec 2005 08:10
I just checked buy kawasaki, as I should of before asking this question, the front rotors are the same part number, but the rear is off by one number. rstnick please check your u2u. Thanks for the reply... Wayne
- rstnick
01 Dec 2005 17:41
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- Old-Skul
07 Dec 2005 19:28
I put SR rotors on my 78 B1 and had trouble. I had to change the fork tubes as welll as the rotors were larger and the calipers wouldn't mate up properly. We originally thought they were the same size - but found out during the install they weren't.
- baldy110
08 Dec 2005 09:20
The fronts bolt right on and work great. The rear will not work because the rotor is thicker than the C models. The SR uses a different rear caliper.
I did this conversion about 15 years ago on my 78 KZ650C1.
