Brake hoses
  • pstrbrc
  • pstrbrc's Avatar Topic Author
  • '81 GPz 1100 project
Brake hoses
09 Feb 2007 14:45
#111214
OK, I've just about gotten everything torn off the bike. I mean, bare frame, man! As I've been taking it apart I've been building a pile of "gotta replace!" parts. I'm at the pile of brake parts, so here's the questions:
#1. I can get Goodridge Universal braided hoses and ends for about $150. What are my other choices? Does somebody sell these cheaper than that?
#2. I'm planning on eliminating the front brake splitter and just run two lines from the master cylinder via a double banjo bolt. Sound OK?
\'81 GPz 1100 project
Elkhart, Kansas USA
\"Man does not control his own fate. The women in his life do that for him.\" Groucho Marx
  • StreetfighterKz
  • StreetfighterKz's Avatar
Re: Brake hoses
09 Feb 2007 15:59
#111226
Have you tried Spielger or Russell brake lines? Also did you price out premade set, or did you price the hoses and the fittings seperately? I would say that $130-$150 sounds about right for a two line front set and a rear line.
I have a Goodridge 2-line set waiting to go on my 'Strip-fighter project. There is no problem running two lines from the M/C except you'll lose the brake light pressure switch but you can run a banjo bolt with pressure switch built in.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • pstrbrc
Re: Brake hoses
09 Feb 2007 19:41
#111294
OK, that's my question. Who do you buy other brake hoses from, if all you have within 100 miles is Hogley dealers? I'm kind of stuck buying through the internet, and I don't find anybody on the 'net that sells brake hoses for a 26 year old bike.:S Am I looking in the wrong places?
And, on my master cylinder, the brake light switch is mechanically operated by the lever movement. I could have NO brake hose, and the brake light would still work!;)
Elkhart, Kansas USA
  • indykaw77
  • indykaw77's Avatar
Re: Brake hoses
09 Feb 2007 19:51
#111296
I found these guys:
www.mgcycle.com/brakelines.html
whilst searching for stainless lines. Scroll about 1/2 way down to "Earl's". $7.75/ft for the lines.....fittings priced individualy. Just got to measure and do the math....:)
Kawasaki Motorcycles...because cars lean th wrong way!
  • Vter Bob
  • Vter Bob's Avatar
Re: Brake hoses
11 Feb 2007 15:12
#111605
Another place I've found for SS brakelines and fittings.
www.pmfronline.com/brake_lines_and_fittings.htm
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
1999 ZG1000 Concours
Greetings from the Peoples Republic of Vermont, home of Ethan Allen, 2 American Presidents, a socialist US Senator and.....Homer & Bart Simpson
  • H1Vindicator
  • H1Vindicator's Avatar
Re: ---- Pegasus Auto Racing
11 Feb 2007 16:00 - 21 Feb 2013 21:17
#111621
Pegasus Auto Racing .
Pegasus Auto Racing
Last edit: 21 Feb 2013 21:17 by H1Vindicator.
  • arobsum
  • arobsum's Avatar
Re: Brake hoses
11 Feb 2007 16:37
#111640
i just saw some NOS stuff on ebay......if i had read this earlier i would have given you a heads up!
  • Robjb84
  • Robjb84's Avatar
Re: Brake hoses
13 Feb 2007 07:04
#112029
H1Vindicator wrote:
Here's a place that has some prefabbed lines - Pegasus Auto Racing . Scroll down - Page 72 of their PDF catalogue has lines in some common lengths made up (at the bottom of the page). The prices don't look too bad.
Kawasaki.com has the brake line lengths listed in the parts diagrams for some bikes. Be aware that at different places the fittings may or may not be included in the lengths listed. I don't know if Pegasus includes the fitting in the lengths there on pg 72.
If the line length isn't known, I find that it helps to disconnect the pipe joint & caliper to measure the hoses. Also, the long zip ties come in handy for measuring, particularly the upper hose. On the bikes with the goofy mini-apehanger handlebars: if new handlebars are installed & a shorter upper hose is needed, disconnect the pipe joint & lower it, then measure the overage & subtract that from the total length of the hose - voila', correct length needed. JMK.
Edit : 81 Gpz1100-B1: 370mm upper hose = 14.5"; 550mm lower hoses (2) = 21.6"; 415mm rear brake hose = 16.5"; 4 straight banjos. Total cost = ~$110 + shipping. Two front line instead of three will save about twenty bucks or so, assuming the 36" lines are long enough (Note: the banjos should add some length).<br><br>Post edited by: H1Vindicator, at: 2007/02/11 20:35
I bought my braided line from pegasus, I give them a thumbs up.
  • H1Vindicator
Re: ----
13 Feb 2007 07:43 - 21 Feb 2013 21:16
#112033
Last edit: 21 Feb 2013 21:16 by H1Vindicator.
  • floridamba
  • floridamba's Avatar
Re: Brake hoses
13 Feb 2007 09:29
#112054
Cycle Gear has the two-line front set for 89 bucks in my area... not specific to a KZ but there is probably a set in the web site that will work.
