Tapered Steering Bearings?
  • Draco
  • Draco's Avatar Topic Author
09 Feb 2007 05:59
#111125
I plan to upgrade to the tapered bearings at some point this year. My question is this, Is the installation if these something I can accomplish on my own without specialized tools, or should I take the bike to a more qualified mechanic? Info on said process would be appreciated as well. Thanks!
  • Biquetoast
  • Biquetoast's Avatar
  • King Jeremy The Wicked
Re: Tapered Steering Bearings?
09 Feb 2007 06:52
#111131
You can definitely do it. If I did, anyone can. You just have to use a very subtle bland of cautious patience and extreme violence...
Do a search, this has been talked about tons...
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
  • donthekawguy
  • donthekawguy's Avatar
09 Feb 2007 07:09
#111135
Don't forget your BFH to pund the races out. It's easy and you will feel good doing it yourself.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • RonKZ650
  • RonKZ650's Avatar
09 Feb 2007 07:13
#111137
You can do it relatively easily really. I don't know how much has been discussed on the subject here, but all you really need to do is remove your front wheel, then the fork legs, then unbolt your top triple clamp and find a way to safely move it out of the way far enough to remove the steering stem then simply pound out the old bearings, then pound in the new. This is where "simply" sometimes turns ugly as there is not a lot of area on the bearing races to beat on and they can be rusted in place. Eventually you will prevail and have new bearings after a little swearing and sweating.
  • Biquetoast
09 Feb 2007 10:11
#111172
RonKZ650 wrote:
...then pound in the new...
Tap!
*Tap* in the new....
kz750twins.com
  • Draco
09 Feb 2007 10:21
#111173
how about TAP with authority?
Thanks for all the input guys.B)
  • CoreyClough
  • CoreyClough's Avatar
  • GPz550 Addiction
09 Feb 2007 11:39
#111185
Easily performed. So easy, even a Caveman can do it!!!
'85 GPz550(ZX550-A2)
  • Draco
09 Feb 2007 12:21
#111193
:blink: Uncle Henry?!?:blink: :woohoo: :laugh: :P :whistle:
  • 76LTD
  • 76LTD's Avatar
10 Feb 2007 05:15
#111323
Hardest part is getting the old races out of the frame. Try to keep them coming out even so you don't roll up a bit of steel in front of the race. If that does happen, re-seat the old race and carefully sand/cut/grind out the small roll of steel. If you get the old races going out crooked, you will hate life.
  • Biquetoast
10 Feb 2007 05:49
#111327
76LTD wrote:
... If you get the old races going out crooked, you will hate life.
Yes, I can vouch for this. I've done these bearings twice now: once it came out perfectly even and was actually kind easy; the second time it got a bit crooked and started to dig in without me noticing. I was thinking, "this is alot harder than I remember"...
...you have to be sooooper-even...
kz750twins.com
