Rear Fender Eliminator Template
  • billz
  • billz's Avatar Topic Author
30 Nov 2005 13:15
#11109
A while back GoneHawkin sent me a copy of his templates for an adapter to eliminate the rear fender on the KZ900/1000. I said I would convert it to pdf and post it. Well he sent it & then work decided it needed my undivided attention so I finally dug it out of my pile of to-dos and did it. It's posted on Filebase. Good luck & thanks to the Hawkman!
Bill
  • 1544courtney
  • 1544courtney's Avatar
Re: Rear Fender Eliminator Template
17 Feb 2020 04:53
#819476
Is there any way you could send me that template I cant find it thanks
  • seanof30306
  • seanof30306's Avatar
04 Apr 2020 14:35
#822618
I've been looking for it too.
Something appears to be up with the filebase, I keep getting a message telling me I don't have access to it.
Can anyone help?
"That @#$%!!! KZ650"
79 KZ650 B3
Dual front disc brakes
Z1R 18" front wheel
Pumper carbs w/pods
MAC 4-1 w/ drilled-out baffle
Dyna S ignition w/ Dyna Green coils
WG coil mod
'81 CSR charging system
17/41 gearing
  • martin_csr
  • martin_csr's Avatar
04 Apr 2020 16:25 - 04 Apr 2020 16:27
#822620
This topic is very old & the file is probably gone. Here's a tail light topic w a bunch of pics that also some fender eliminator info. Z1Enterprises.com has a kit shown in the topic. maybe you've already seen the Z1Ent kit.
KZR topic >> Can anyone recommend an AFTERMARKET tail light? *PICS* . the topic has 8 pages w lots of photos.
Last edit: 04 Apr 2020 16:27 by martin_csr.
  • billz
04 Apr 2020 17:04
#822623
I occassional check in here to see what's happening. I need to get my bike running after it has sat for 6-7 years and I came across this post.
I might still have this file somewhere, but since it was almost 15 years and a major move ago, who knows. I spent the last hours looking through my archive hard drive with no luck. I have a couple of other places to look so if I find it I'll post it. It seems like I saw it, but whether I deleted it thinking, I don't need this any more I'm not sure.
Bill
