1100 forks on a 1000
- wagonmaster69
- 78 KZ1000A2 / 82 KZ1100 Spectre
03 Feb 2007 21:54
Will forks from a 82 KZ1100 shafty fit on my 78 KZ1000
simple bearing swap or more in to it than that?
- Zthou1977
Re: 1100 forks on a 1000
05 Feb 2007 06:45
If I recall correctly these are leading axle. So it will alter your steering geometry, and not in a good way.
There is a list of all the steering-stem bearings that allows you to check which forks are interchangeble. It is either in the filebase or on the forum. A search should bring it up.
1977 Z1000A1, 1982-1986 KZ1000P (built from two piles of parts), Moto Martin Z1200 (trying to get it registered), 1977 Z650B1
Utrecht, The Netherlands
- wagonmaster69
06 Feb 2007 15:15
What if I lower the forks in the tripple trees or swap the forks from one side to the other?
