Where to buy BEARINGS?
  • Nelson
  • Nelson's Avatar Topic Author
29 Jan 2007 22:57
#109107
I'm fitting an enkei front wheel from a 82 gpz1100 on my 78kz1000. I need a different size of bearings and seals. I'm sure I can get bearings at a local bearing house, but what about seals? No idea what model bike might have the right size, so I need to order seals based on the dimensions I provide.
FYI - this is cause I'm using the thicker axle from the old bike and the new wheel used a thinner axle.
SO - anyone know where I can order seals by dimension?
OR - maybe a list of dimensions of seals and bearings from other bikes. Then I could order a bearing and seal kit by model.
thanks
Post edited by: Nelson, at: 2007/02/03 01:31
Restoring and customizing a KZ1000. Click here to read about it.
Plated KTM, DR650, KZ1000, Former MC mechanic (eons ago). 40 yrs. of dirt and street.
  • OKC_Kent
  • OKC_Kent's Avatar
Re: Where to buy seals by dimension?
30 Jan 2007 06:32
#109127
I have not used this place but they have a huge amount of seals, I don't know if you need to order a minimum amount, which may be your downfall on something custom. Do you know your seal dimensions?
www.epm.com/
Cashion, OK
78 KZ650 B2 85,000+ miles
  • Duck
  • Duck's Avatar
  • e vica na i sau na ga
30 Jan 2007 08:06
#109141
Why not go with sealed bearings?
You can also buy seals from most bearing dealers.
NTN, SK, Timken, ...
If you look in your local phonebook under bearings, there should be an 800 number to a regional dealer. They'll sell you what you need over the phone. You can order through NAPA but unless you kow the old guy is still working there it's est to bring in a mess of acceptable part numbers. Your local tractor parts store is the best bet for knowledgeable help.
  • KaZooCruiser
  • KaZooCruiser's Avatar
30 Jan 2007 08:22
#109143
You might try this link:
smp.applied.com/
to locate a dealer near you. They may have a seal that will work for you by dimension, but make sure you do NOT say it is for ANYTHING to do with a motorcycle application. You will provoke a deer in the headlights reaction, just before they tell you they can't help you.
  • Nelson
31 Jan 2007 09:28
#109374
THanks for the tips. EPM looks good. I never thought of a tractor place, there's one close by. I'll ask them.
yes, I'm planning to use sealed bearings, but the hub just looks wrong without the external seal as well. And OEM setups usually use both.
  • steell
  • steell's Avatar
31 Jan 2007 11:28
#109387
78 KZ1000 has a 20mm rear axle, and so does the 83 GPz1100, are you sure that the axle on the new wheel is smaller, and if it is, are you sure it's off a 1100?
The 81-82 GPz1100's might have used a smaller axle than the 83's, I am not real familiar with the 81's and 82's.
  • Nelson
31 Jan 2007 11:53
#109391
I'm swapping the Front wheel now, not the rear. (that'll be another post later :)
  • Nelson
Re: Where to buy BEARINGS ?
02 Feb 2007 22:30
#109848
Well, the saga continues... Silly me to think a bearing house would have what I need. I want 17mm ID, 42mm OD. Noone seems to make this size.
I've looked up Applied and some other sites.
tried local brng house, parts stores, etc. I may
have to use the smaller axle that goes with the
new wheel. This would work, but I'd have to get
some custom sleeves made. The collars (nuts) on
the ends of axle are a smaller OD and the fork
leg clamps are too big for them. Also need
sleeve for the old speedo drive - new one is
electronic. buying bearings would be so much
easier!
ideas?
thanks
  • guitargeek
  • guitargeek's Avatar
  • Elitist, arrogant, intolerant, self absorbed.
03 Feb 2007 02:00
#109852
I know I sound like a broken record, but have you checked with Jeff Saunders?
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
  • wiredgeorge
  • wiredgeorge's Avatar
03 Feb 2007 07:21
#109884
When you asked your bearing place, did you ask them for electric motor bearings? That is what they will know them as...
  • 76LTD
  • 76LTD's Avatar
03 Feb 2007 09:45
#109903
Check, for bearings and seals, or sealed bearings, with your local bearing buisness. I am always amazed whet these guys have or can get. The prices are usually always better than web shops or MC dealerships.
  • Duck
  • Duck's Avatar
04 Feb 2007 05:05
#110065
Looks to be a bit of an odd size.
If the wheels original application was for a larger axle, why not bush your 17mm axle up to the original size?
