will kz1000 rear wheel (w/ disc) fit 78 kz650c
- keyzerdm
27 Jan 2007 17:48
Does anyone know offhand if a rear wire wheel w/ disc from a late 70s KZ1000 will fit my 78 KZ650 C2. I'm looking at this one on eBay (and equivalents):
KZ1000 wheel on eBay
Thanks,
Post edited by: steell, at: 2007/01/27 21:08
Thanks,
- steell
Re: will kz1000 rear wheel (w/ disc) fit 78 kz650c
27 Jan 2007 18:15
The KZ1000 has a 20 mm rear axle, while the 650's up through at least 1980 have a 17-18 mm rear axle. The front wheel of a 76-80 750 twin and a 77-80 KZ1000 will work on the 650, but not the rear.
You can look at the wheel bearing chart in the filebase to see which models use the same rear wheel bearings.
- 77KZ
27 Jan 2007 18:16
Check your PM. I have a rear spoke but with drum brakes. Will help if possible.
"What do you mean we can't change the alphabet to W,X,Y,K,Z!"
Western, OH, Formerly... Western, NY
1978 KZ650B, 1979 KZ650C, 1978 KZ750B, 1982 KZ750 LTD, 2006 ZX-6R, 2009 Ural Gear Up, 1974 Yamaha DT360 (It's Green Anyway!)
- keyzerdm
27 Jan 2007 18:28
Thanks for the tip; I'll take a look at the wheel bearings list.
