Fork oil capacity for 1000 J ?
- KawasakiBob
27 Jan 2007 11:58
Anyone know the capacity of fork oil in an 82 1000 J forks?
- steell
Re: Fork oil capacity for 1000 J ?
27 Jan 2007 12:30
KawasakiBob wrote:
Not off hand, but I'll look for my manual and edit this post when I find it
Found it.
Oil change; about 300 cc
Completely dry: 327+- 4 cc
SAE 10W20 oil
Oil Level 110 +- 2 mm
Measure the distance between the top of the inner fork tube to the surface of the oil.
Post edited by: steell, at: 2007/01/27 15:37
Found it.
SAE 10W20 oil
- KawasakiBob
- themachine
27 Jan 2007 18:12
steell wrote:
how does one go about putting new oil into a set of forks, mine arent holding too well.
have 83 1000 j forks
KawasakiBob wrote:Anyone know the capacity of fork oil in an 82 1000 J forks?
Found it.
SAE 10W20 oil
Measure the distance between the top of the inner fork tube to the surface of the oil.<br><br>Post edited by: steell, at: 2007/01/27 15:37
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
- steell
27 Jan 2007 20:34
Release the air pressure, remove the bottom drain plugs and drain out the old oil, remove the fork caps and refill.
A manual is a real good idea, and they are fairly cheap on eBay.
Your sig says you have a CSR 1000, do you have a 1000J also, or J forks on your CSR?
The CSR forks have the axle mounted in front of the fork tubes, while the J (Standard) has the axle at the bottom of the fork tubes.
Post edited by: steell, at: 2007/01/27 23:37
