tank dampers
- rotorhead488
tank dampers
26 Jan 2007 19:38
Help! I have an 83 kz 550 a4. I need a rear fuel tank damper. anyone know where I can find one? I have looked on ebay and Z1 with no luck. I got the pucks but the rear one fell apart when I took the tank off.
- sbodi4d
Re: tank dampers
26 Jan 2007 19:55
Try this place, I haven't used them yet, but probably will give them a try sooner or later.
www.thriftyrider.com/partsfish/displayfiche.asp
- JR
Re: tank dampers
26 Jan 2007 20:24
When I needed a rear damper for my gastank - it's slightly different from yours - I had this kinda ruberised thick mudflap from a pickup truck lying around and so I cut 2 and glued them together for the correct thickness.
- tkaser
Re: tank dampers
27 Jan 2007 08:33
Just wondering what does it look like? I have a ZX750 GPz and it took 2 dampers that attached to the bracket that held the fuel tank, if it is the same I have extra's just a thought!
tkaser
tkaser
- rotorhead488
Re: tank dampers
27 Jan 2007 11:53
Thanks for the assist thriftyrider.com had what I was looking for. Definitely going to book mark that site.
