  • H1Vindicator
  • H1Vindicator's Avatar Topic Author
26 Jan 2007 17:24 - 21 Feb 2013 21:14
#108385
Last edit: 21 Feb 2013 21:14 by H1Vindicator.
  • wireman
  • wireman's Avatar
Re: Tires and RRW
26 Jan 2007 17:32
#108388
sidewalls would be pinched in on a smaller rim;)
  • steell
  • steell's Avatar
Re: Tires and RRW
26 Jan 2007 18:49
#108415
You sure the tire would even fit between the fork tubes? My nephew's 79 KZ650SR has a 110/90/19 on the front, and it's a real tight fit.
  • H1Vindicator
Re: ----
27 Jan 2007 19:25 - 21 Feb 2013 21:15
#108658
Last edit: 21 Feb 2013 21:15 by H1Vindicator.
  • steell
  • steell's Avatar
Re: Tires and RRW
27 Jan 2007 20:24
#108671
I run 100/90/19 tires on 1.85 rims, and I suspect that anyone else with that size rim does the same. My nephew's 79 650SR has a 110/90/19 on a 2.15 rim.
The Dunlop GT501 100/90/19 calls for a 2.15 rim, but I had it on a 1.85.
The Bridgestone BT45 100/90/19 says 2.15 to 2.75, but I would run it on a 1.85 rim and not worry about it.
  • H1Vindicator
Re: ----
28 Jan 2007 13:14 - 21 Feb 2013 21:15
#108783
Re: Tires and RRW
28 Jan 2007 15:14
#108801
Here's what Dunlop recommends for your 1.85 rim
www.dunlopmotorcycle.com/fitmentguide.asp
Kawasaki | Model: KZ 650 H (81-83) - CSR
Front Rim Size: 1.85x19 | Rear Rim Size: 3.00x16
Recommended Front Tire:
Tire : GT501 | Size : 100/90-19 | PSI/Loaded : 32
Click for Info
Recommended Rear Tire:
Tire : GT501 | Size : 130/90B16 | PSI Rear/Loaded : 36
Click for Info
Alternative Front Tire:
Tire : Elite 3 | Size : MM90-19 | PSI/Loaded : 32
Click for Info
Alternative Rear Tire:
Tire : Elite 3 | Size : MT90B16 | PSI Rear/Loaded : 36
Click for Info
** - Available only from O.E.M
TT - Tube type tire only
Post edited by: Patton, at: 2007/01/28 18:16
  • steell
  • steell's Avatar
Re: Tires and RRW
28 Jan 2007 15:26
#108807
H1Vindicator wrote:
My rims are labeled as M.T. 1.85 x 19. What does M.T. 1.85 mean? Using a tape measure the rims appear to be between 2.50 & 2.75 inches wide - or about 2 5/8".
Also, when a tire is listed as JMK.3.25/3.50 x 19, what exactly is meant by 3.25/3.50? I know it's 3.25" & 3.50 " and refers to the tire width, but what would be the actual width of the tire?
I guess a link to a tire info page would be handy. JMK.
Rim width is measured inside bead to bead, not outside across the rim.
Here is a link to the tire marking explanation at Metzeler
  • H1Vindicator
Re: ----
28 Jan 2007 16:06 - 21 Feb 2013 21:12
#108818
Last edit: 21 Feb 2013 21:12 by H1Vindicator.
Re: Tires and RRW
28 Jan 2007 17:06
#108828
Lots of information about tire sizes on these two sites.
Hope they may be helpful. :)
www.steelthundercc.com/tiresizes.html
www.webbikeworld.com/Motorcycle-tires/tire-data.htm
