Mono Shock conversion Nearly Done
- steell
Re: Mono Shock conversion Nearly Done
28 Jan 2007 16:17
295 lbs wet sounds awful light, especially considering a Zx10 has a dry weight of 375 lbs.
Some rough numbers off the top of my head.
3 gallons of gas = 21 lbs
Battery = 5 lbs
KZ650 motor with carbs 180 lbs
That's 204 lbs, that leaves less than 100 lbs for a steel frame, lights, full suspension/tires/wheel/etc.
Possibly your scale was off?
Battery = 5 lbs
- caffcruiser
28 Jan 2007 17:21
steell wrote:
I was gonna say that too.... not to call BS, but there's no way the bike is 295 lbs... especially wet.
Battery = 5 lbs
- indykaw77
28 Jan 2007 17:33
Regardless of weight, I still wanna see close ups and all of the rear mono set up. I think that SO cleans up the back of the bike.
Whats the swingarm off of? Did the "donor" shock mount NOT have the dog-bone hooya R4 asked about?
Whats the wheels off of? Good lookng, those....I know...lotsa questions! :blink: :S
And hats-off on the under tank electrics....nice and clean...
Post edited by: indykaw77, at: 2007/01/28 20:48
Post edited by: indykaw77, at: 2007/01/28 22:18
Kawasaki Motorcycles...because cars lean th wrong way!
- steell
28 Jan 2007 18:13
Don't get the wrong idea, I'm not saying anything bad about the bike or the owner, I think that the number was probably mistyped or maybe the scale was off. My guess is that it should say 395 lbs wet, and that is impressive enough
- EddieBoy
28 Jan 2007 18:19
sorry for the typo...should be 395. weighed at the local scrap yard. i can verify if yall need me too. was actually 393.17
which i thought sounded heavy.
the battery weighs 2 lbs and the frame weighed 41 lbs with the cleanup and new shock mount
The frame/swingarm doner was a 1992 yamaha diversion\seca2. no dog bone. the dogbone is only there to make the shock mount lower in the frame.
the electrics are under the fuel tank not the seat. was very simple to wire.
there are still lots of things to do. it will go through a repaint and all the final touches when i install the 900 motor again.
- steell
28 Jan 2007 18:57
395 lbs is something to be proud of, sheesh, a stock KZ650 weighs in at ~490 lbs wet, and Kawasaki's wicked Zx10 weighs in at over 400 lbs wet :woohoo:
- 77KZ650
29 Jan 2007 13:44
OK, Ill admit it now, I might steal the battery placement idea:P nice work. I thought mine was going to fit in the stock location, but then I switched shocks to be able to put on the hugger fender, and its in the way of the battery now:pinch:
07 MDP Rookie of the Year
- indykaw77
29 Jan 2007 16:40
77KZ650 wrote:
Uhm....hugger fender?? Are there no pics of this???? And if not, WHY not?? j/k 77KZ650....have followed this project of yours when I can. I still really like these mono-shock setups......
- EddieBoy
30 Jan 2007 01:09
your welcome to copy the battery idea...im sure someone somewhere did before myself. i would dream of claimin rights...but
this is a 900 frame im not sure if a 650 frame is the same.
also thats where your factory coils are mounted.
i moved mine to just under the steering neck.
also the front tank mounts were relocated to the center of the frame tube instead of under it.
i had a goal is why the battery is under the tank...
i wanted the bike to be skeletal...see no wires or battery.
minimal is what i had in mind.
i have a different tank for the bike, large homemade fiberglass tank i got on ebay. heres a pic.
- EddieBoy
30 Jan 2007 01:12
Thats an old pic though...that was before i put on the rear sets.
- 77KZ650
30 Jan 2007 07:26
indykaw77 wrote:
not sure what thread they are in now, so heres a couple again, remember I still have to paint everything:whistle:
one of the zx light I tucked up into the tail
Im not using this brake caliper, I have one from a 636 on there now
the pics show the shock Im not using. you can see in the first pic where it hits the hugger as soon as the swingarm comes up a bit.
the shock is up for grabs cheap btw:whistle:
Scott
Post edited by: 77KZ650, at: 2007/01/30 10:40
Its just stock 636 stuff, I posted them as soon as I had the pics!77KZ650 wrote:OK, Ill admit it now, I might steal the battery placement idea:P nice work. I thought mine was going to fit in the stock location, but then I switched shocks to be able to put on the hugger fender, and its in the way of the battery now:pinch:
Scott
- loudhvx
30 Jan 2007 17:57
That's awesome Eddieboy!
I took a bunch of stuff off of a 550 and came down to 430 pounds, but not nearly as much stuff as you took off. 395 sounds right considering how much you took off and all the newer parts. Great job!
Post edited by: loudhvx, at: 2007/01/30 21:03
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
