  • H1Vindicator
  • H1Vindicator's Avatar Topic Author
22 Jan 2007 10:52 - 21 Feb 2013 21:09
#107447
Last edit: 21 Feb 2013 21:09 by H1Vindicator.
  • mariozappa
  • mariozappa's Avatar
Re: Changing tires: Do-able?
22 Jan 2007 11:06
#107452
Yes, you can definitely do them yourself.
I've done several in the last couple years.
It helps to have a friend help, four hands are better than two.
The first time may seem difficult, but each time gets easier and easier.
Now let me see if I can find that cool do-it yourself article....
1977 KZ650C1
and the KZ650/KZ750 Conversion ;)
  • mariozappa
22 Jan 2007 11:10
#107453
Here it is
www.clarity.net/~adam/tire-changing-doc.html#0
Check out the 2x4 lever they used to break the bead.
BTW, the rim guards are nice. But you can save some $$$ by using empty plastic bottles like oil bottles or shampoo bottle. Just cut strips out of them and you can use them a couple times before they are trash.
Post edited by: mariozappa, at: 2007/01/22 14:10
1977 KZ650C1
  • Duck
  • Duck's Avatar
  • e vica na i sau na ga
22 Jan 2007 18:38
#107533
If the tire has been on there for 20 years, it's gonna be a PITA even with that block of wood and the press. IMO it's well worth $5-$10 to have someone with an air operated bead breaker get the old tire off. Fresher install comes off much easier.
It's a good idea to clean all corrosion off the rim with wire brush and sand paper. Use tire mounting 'wax' and your replacement will go on easy and it won't corrode further. A careful cleanup and it will hold air very well.
