KZ Front Wheel- Does a 77 fit a 76?
  • thetemples
  • thetemples's Avatar Topic Author
22 Jan 2007 07:29
#107418
Hello !
Does anyone know if a KZ900 front wheel from a 1977 will bolt right up on a 1976?
Thanks!
  • wireman
  • wireman's Avatar
Re: KZ Front Wheel- Does a 77 fit a 76?
22 Jan 2007 07:34
#107422
yep,you can use same rotor also 78 will also fit;)
  • thetemples
23 Jan 2007 12:30
#107687
Saaweet. Thanks.
  • DanVVArider
  • DanVVArider's Avatar
23 Jan 2007 13:18
#107700
How about 1979 KZs? Will they interchange? The rear took some work, and I haven't done the front yet.
"CHOP 'TIL YA DROP!"
  • wireman
  • wireman's Avatar
23 Jan 2007 16:24
#107728
79s and 80s had mags,if you get all the spacers to go with it should also work;)
  • DanVVArider
23 Jan 2007 21:23
#107793
Not all 1979s came with mags...in fact, I'm replacing spokers with mags, to lower the ass end (front is just to match the rear)...the replacement wheels came whole and intact, with crappy tires, so I guess I'm good to go (with new tires, of course)...
  • wireman
  • wireman's Avatar
24 Jan 2007 15:14
#107933
i was thinking about kz1000s;)
  • ltdrider
  • ltdrider's Avatar
24 Jan 2007 15:17
#107935
thetemples wrote:
Hello !
Thanks!
I love these trick questions.
Temples, Kaw didn't make a KZ900 in 1977. If your wheel is from '77, then it's likely from a KZ1000.
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
  • wireman
  • wireman's Avatar
24 Jan 2007 15:35
#107941
yes that is a trick quesion there are some early 77 900s floating around out ,ive seen a couple of them;)
