530 offset sprocket
- chetriply
530 offset sprocket
19 Jan 2007 07:51
I know I've seen this on here before but can't seem to find it. Does anyone know where I can get a 3/8" offset front sprocket for a 530 chain? I'm swapping a ZRX swinger onto my 81 KZ and need the front sprocket. Thanks in advance.
- Bad Kaw
- Flying Squirell
Re: 530 offset sprocket
19 Jan 2007 09:07
Either Kosman or Precision Metal Fab Racing.
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
70 Kawasaki KV75
- chetriply
- Fossil
20 Jan 2007 19:32
Russ here told me that he found the 1st model ZZR1000 used a 17 tooth 530 sprocket with the same spline that should clear a 170 rear tire. Another alternative is to machine the teeth off the original 630 sprocket and weld a 530 sprocket ring to it.
- 77KZ650
22 Jan 2007 08:23
I believe
Kosman
can make what you need;)
Scott
Scott
07 MDP Rookie of the Year
- big mike
24 Jan 2007 16:26
pmfr is the best place to get them they will make what you need ok kosman is just to spendy $kostman$
