new sprockets and chain?
- rotorhead488
17 Jan 2007 17:39
I've got an 83 kz550, was wondering if anyone could suggest a sprocket and chain set up. should I stay with the stock tooth count? or go with a different size.
- RetroRiceRocketRider
Re: new sprockets and chain?
17 Jan 2007 21:09
First off, welcome to KZr rotorhead.
It all depends on what you're wanting to achieve:
A front sprocket with a higher tooth count (or rear sprocket with a smaller tooth count) will give you a higher top speed and better fuel mileage if driven smoothly. But your bikes acceleration may suffer slightly, since it will take more time to reach that top speed.
A front sprocket with a smaller tooth count (or rear sprocket with a higher tooth count) will give you faster acceleration, but you won't have as high of a top speed and your fuel mileage will suffer.
So I'd suggest basing the change on what type of riding you mainly do. You'll also want to factor in any gear (plus weight of rider, and passenger if any) that you'll be carrying with you, as that will also effect performance.
The best way to do it is one tooth size change at a time, that way you won't be to dissapointed if the results are more/less than you had expected.
You'd be surprised at how much just one tooth size diff will make in how your bike performs.
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
- KZQ
- Administrator
18 Jan 2007 03:59
Hey Rotorhead,
You'll be surprised at how well the stock setup works. Change if you have a real need but if your gonna use the bike for regular street riding Ma Kaw knows best.
KZCSI
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- rotorhead488
18 Jan 2007 16:31
Hey guys thanks for the welcome and the info. I'm in the middle of fixing it up. its in pieces in my kitchen. My first bike. I was happy with the way it ran. The top end was not too impressive but but it ran pretty well. figured I'd fix it up over winter, new tires, new fork seals, paint job, that sort of stuff.
Lots of questions.
Lots of questions.
