Custom Swing Arm
  • JAILBAIT
  • JAILBAIT's Avatar Topic Author
Custom Swing Arm
10 Jan 2007 13:38
#104779
I am looking for a custom +10 over swing arm to be put in a 7in tire class. Anyone build them or know of someone that builds them
  • 77KZ650
  • 77KZ650's Avatar
Re: Custom Swing Arm
10 Jan 2007 14:50
#104793
07 MDP Rookie of the Year
  • donthekawguy
  • donthekawguy's Avatar
10 Jan 2007 22:26
#104884
Les Holt is a member here who builds anything you want. Do a search for him or try justlesh@yahoo.com. I think that is his email.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • JAILBAIT
11 Jan 2007 06:18
#104898
77KZ650 wrote:
I really don't want to go with trac, that arm would be over a grand, I know I could just have a builder do it for less.
I will give this a try thanks.
  • 77KZ650
  • 77KZ650's Avatar
11 Jan 2007 12:47
#104963
A much cheaper option(ebay the parts), but wouldnt get you 10+ would be a zx12r or gsx1300r arm with matching wheel. after you mod it to fit, (and either go the whole 9 yards and go with a mono shock or weld on mounts for dual shocks) you can get swingarm extensions for about $200 to give you 4-6 over. plus the new arms are about 2-3 over compared to the kz arm. so a total of 8-9 over.
if thats not enough, I know muzzys can add 3 or 6 inches to the zx12 arm($500-$600:( ), then put on the bolt on extensions and you would be well over 10 then. about 14-15 max.
the wheels come with a 200mm tire stock(allmost 8 inches wide) so thats in the ball park. just add the slick you want
Scott
Post edited by: 77KZ650, at: 2007/01/11 15:51
  • JAILBAIT
11 Jan 2007 13:48
#104983
Thanks for the info guys. i will see what i can do
  • wireman
  • wireman's Avatar
11 Jan 2007 19:03
#105077
im no big time dragracer but im just wondering is ther a point where you can lengthen the swingarm too much where it starts to affect traction from a lack of weight on rear wheel?the most ive ever gone is around 4" over on any of my projects;)
  • racer54
  • racer54's Avatar
11 Jan 2007 19:12
#105083
Yep...there is a limit, but it depends mostly on your tire. Get it out back too far and with no wieght on the tire, you better have a sticky one. I've seen some bikes with the rear tire so far back there wasn't any of it under the stock body work...but they were running a 7" M/T slick. Farther back you go, the better tire you will need..and a very big turn-around area!!!
  • wireman
  • wireman's Avatar
12 Jan 2007 06:53
#105146
thats what i was thinking!:P
  • donthekawguy
12 Jan 2007 08:28
#105167
When I spoke with Les he said he can make an arm for $200 to $250. Not bad at all.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
  • big mike
  • big mike's Avatar
24 Jan 2007 16:47
#107965
i build swingarms ( i used to work at trac long time ago lol) motorsportsunlimited.net all my infor is there ok call ill help you out ok B) i can build ant thing ok lol:evil:
