Jacking against oil pan?
- EsaPro
08 Jan 2007 18:52
Since it's about raising the chassis, I posted here
The spiffy new lift I got has two rubber-covered arms that are intended to slide under the bike from the side, and lift it by the lower frame rails. Sounds great, but on the 79 twin, the oil pan is lower than the frame rails.
Am I screwed, or is it safe to lift this puppy pushing on the bottom of the engine like that?
Jim
79 KZ750 Twin (Fun!)
07 Yamaha 1300 (Plush!)
- steell
Re: Jacking against oil pan?
08 Jan 2007 18:57
The problem is that the twin will fall over when you try jacking it up on the pan.
I stick a 2x4 under the lower frame rail and jack on that.
I have yet to find a good use for one of those motorcycle jacks
- KZ250LTD
Last edit: 04 Aug 2009 11:14 by KZ250LTD.
- donthekawguy
08 Jan 2007 21:07
When jacking it up use a racheting strap under the seat on top of the frame.That will keep it from falling over.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- bill_wilcox100
08 Jan 2007 21:32
We must have bought the same bike jack... mine was on sale from Canadian Tire. I had to make a plywood adapter to fit the irregular contours of the bottom of my bike (especially the oil plug) to get it to do its job. Oh, and you'd be wise to consider that strap. Don't ask me how I found out.
Best of success.
Best of success.
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Upgrades:
Montreal, Canada
- EsaPro
09 Jan 2007 16:23
Bill - I got mine from a friend, for fairly cheap - looks like this:
Jack thread
I already took the pipes off, since I need to clean them up & perhaps paint them. Found it was blowing by around the exhaust gasket! The strap(s) is/are a definite! I really don't want to be wrenching & banging on 500lbs of bike that is just perched on anything!!
Need to acquire a 2x4.....
Jack thread
Jim
- KZQ
- Administrator
09 Jan 2007 20:12
Hey Steve,
I figured out how to make one of those jacks pay off.
I know, you've seen it before. I jes couldn't resist.
Kzcsi
Post edited by: KZCSI, at: 2007/01/09 23:13
Post edited by: steell, at: 2007/01/09 23:51
Kzcsi
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- steell
09 Jan 2007 20:55
Yeah, I am gathering parts to make a bike lift table, but I don't think that one goes high enough.
I got a hydraulic foot pump with reservoir for free, got most of the needed metal, and now I'm just waiting for the right hydraulic cylinder to come along
Plus the ever lacking time and space
