CB 650 Fork Removal/ Seal Replacement
- Shoey949
26 Nov 2005 17:51
I have a 1982 Honda CB 650 Nighthawk. I know this is a KZ forum but this is THE BEST motorcycle forum. I'm in the process of replacing the fork seals. However in my clymer's manual it says that the forks must be removed by a dealer because they need a hydraulic press to take them off. Is this true? I really don't want to take them in, and will try just about anything myself before taking them to the honda dealership.
Thanks,
Nate
Thanks,
Nate
'83 GPz550H2 w/'81 GPz 550D1 engine
Dynojet Stage 3 kit, MAC 4-1, UNI Pods, DYNA coils and plug wires, WG ignition mod
Grand Rapids, MI
Grand Rapids, MI
- OKC_Kent
Re: CB 650 Fork Removal/ Seal Replacement
26 Nov 2005 19:16
Do your triple trees have bolts that you can loosen to let the forks slide out? I can't imagine a press being needed to remove forks.. maybe for steering head bearings.
Here is a link to a Yahoo group for the CB750's. They might help if no one here can...
autos.groups.yahoo.com/group/cb-750/
I also found this link to a General Service Manual for Hondas. The front suspension starts at page 259.
www.vf750fd.com/vf750f/Honda_Common_Service_Manual.pdf
Post edited by: OKC_Kent, at: 2005/11/26 22:29
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
- Duck
- e vica na i sau na ga
27 Nov 2005 03:53
IIRC a press is only required for the bottom bushings on the tubes with manual recommendation to replace if all the copper is worn off. -Duck
- Shoey949
27 Nov 2005 08:14
I'm sorry my initial post was too vague. I need to take the fork sliders/tube off the fork because I need to replace the fork seals. I have tried to pull the fork sliders off of the fork, butit is like I am running into something. Do I need to gently hammer them off or what?
Thanks,
Nate
Thanks,
Nate
Grand Rapids, MI
Grand Rapids, MI
- OKC_Kent
27 Nov 2005 18:44
There is a bolt or allen head screw at the bottom of the fork, where the axle sits. Have you removed that? It will keep the forks from separating.
Oklahoma City, OK
- Shoey949
28 Nov 2005 12:52
Yes I have removed that, it was an allen head screw sitting ina recessed postion on the bottom of the forks, but when I go to pull the fork tubes of the main fork it won't come off. The slider will move much farther down then it did before the allen head screw was off, but not all the way.
Grand Rapids, MI
Grand Rapids, MI
- Duck
28 Nov 2005 13:49
AFAIK the only thing keeping the piston in the cylinder is the retaining ring that's under the dust boot. There is a backing 'washer' behind this that may need a little coaxing if the aluminum has corroded, but it shouldn't require a hammer.
My CB650 manual has disappeared. I think it's up at the workshop with the bike. I hope to be up there working on the cb650 tomorrow.
-Duck
-Duck
- Shoey949
28 Nov 2005 14:27
Thanks Duck I just figured it out a couple minutes ago. Sorry I'm new to the motorcycle thing, been an owner for less then a year and for some reason I always thought the dust seal was the fork seal.
Grand Rapids, MI
Grand Rapids, MI
- Shoey949
29 Nov 2005 16:06
I removed the retaining ring below the dust cover, and above the fork seal, but I still can't seam to get the fork off and I don't see any washer.
Thanks,
Nate
Thanks,
Nate
Grand Rapids, MI
Grand Rapids, MI
