300 extended swing arm
- foxygoliath
05 Jan 2007 21:16
Hi everyone are there 300 extended swing arm kitS for kz bikes I see them for the new bikes but I can't find any for the old kz's. If so who makes them and do you have any pics of what it looks like. SORRY IF THIS TOPIC HAS BEEN COVERED IN PREVIOUS POSTS I AM A NEWB SO GO EASY ON ME.
- btchalice
Re: 300 extended swing arm
06 Jan 2007 15:48
nobody makes a kit for that .it would require at least a 3inch offset sprocket that would move the chain to the outside of the frame. and the sprocket would need an external bearing for support
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
- wireman
06 Jan 2007 15:55
yeah a 180-190 tire takes a lot of motor to turn,but can still run chain inside of frame;)i have seen custom made arms that ran the chain inside of frame like stock to a wide double sprocket built into swingarm that allows second chain to run outboard of wider tire but you are talking serious money to have one built,maybe try trac dynamics;)
Post edited by: wireman, at: 2007/01/06 19:05
