drag racers-sprocket question
  • donthekawguy
  • donthekawguy's Avatar Topic Author
02 Jan 2007 22:11
#103106
I'm having a hrad time fnding anyone who sells a 18 tooth-3/8 offset front for a 530 chain. I think I'll have to go with the 630 set up. Anyway, what size rear sprocket would be a good starting point? I have a 14 front now but will probably go back to a 15 front. The rear I have on it now is pretty small I want to guess about a 35 or so. I was thinking about getting a 45 for now and see what happens. What are you guys using?
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • 77KZ650
  • 77KZ650's Avatar
Re: drag racers-sprocket question
02 Jan 2007 23:57
#103108
can you make one? or know guys that can?
check out kosman , they make custom sprockets for KZ's
Scott
edit for link
Post edited by: 77KZ650, at: 2007/01/03 03:30
07 MDP Rookie of the Year
  • big mike
  • big mike's Avatar
03 Jan 2007 21:07
#103288
well i think thatthe 14 is to small its hard on the chain with a 630 we run a 15 42 with the kz trans and i have gone 8.62 if you have any other Qs just call ok 253 582 2486 im here all the time lolB)
  • big mike
  • big mike's Avatar
03 Jan 2007 21:09
#103289
i think i have a 19 stock style here some where lol ill look tomarow ok
  • donthekawguy
03 Jan 2007 23:06
#103291
I think I'm going to stick with the 630 and try the 15/42 set up. Thanx! I went with a 14 tooth last year with the tiny rear sprocket and knocked about a second off my times! But with the bigger rear I was concerned about the binding. I don't know why I was so set on changing to a 530 chain. I guess it's the new thing to do. :woohoo:
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
  • 77KZ650
  • 77KZ650's Avatar
03 Jan 2007 23:18
#103292
the new 530 chains (good ones) are as strong or stronger than the old 630 chains, are lighter, cheaper and should cut down your ET a little bit
that could be why:whistle:
  • big mike
  • big mike's Avatar
05 Jan 2007 18:23
#103636
well the new 530 chains like pro stock are runnin are real good . spendy , i think the 15 42 is going to be good for you and your wallet but if you need any help just call ok
:woohoo:
