750 GSXR swingarm?
  • Jack
  • Jack's Avatar Topic Author
750 GSXR swingarm?
30 Dec 2006 09:56
#102490
I have an opportunity to buy a 1990 750 Slingshot GSXR swingarm for my KZ 1000.
I checked the search first and didn't find info. on this particular conversion - anybody done it? I know the GS swingarm deal for KZ's but not this one. Thanks.
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
  • Bad Kaw
  • Bad Kaw's Avatar
  • Flying Squirell
Re: 750 GSXR swingarm?
30 Dec 2006 13:36
#102511
Not yet, but I will within about 2 months as I'm putting one on a 'project' of mine. The front of the GSXR arm works better than some b/c it does not widen-out in a short space like some arms do. Basically by the time it goes from the pivot point to the rear axle area it needs to be "so wide" so that the tire/wheel can fit in. Some swingarms start widening at the pivot point junction and on a 'J/GPz' that area of the frame has significant material around it and it interferes with the swingarm b/c it's wide (close to the junction). Gixxer arms gradually widen and (on mock-up) have fit into the frame with ease.
When this project starts I'll post up with pics, knuckle-busts, and cursings.;)
Post edited by: Bad Kaw, at: 2006/12/30 16:37
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
  • StreetfighterKz
  • StreetfighterKz's Avatar
30 Dec 2006 14:04
#102514
Hey,
I'm also doing the conversion. All I need is a mono shock and some material to make all the mounting points for the shock/ shock linkage. The 750 arm is a bit narrower than the stock arm. You will have to use some washers to set the side to side placement. Also the 750 arm uses a bigger pivot bolt than the Kz but I've found an easy (although not sure about $$) fix. Go to your local Suzuki dealer and purchase the inner races for a 86-88 1100/ 86-87 750 Gixxer. All of these arms use the same pivot bearing but the earlier ones have the same pivot bolt diameter as the KZ. This keeps custom parts to a minimum. I'll let you know any other problems I run into as I move along.
Thanks Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • StreetfighterKz
30 Dec 2006 14:06
#102515
Here's one pic
1979 z650 Resto-Mod
2018 Z900RS
  • StreetfighterKz
30 Dec 2006 14:17
#102516
Here's a pic of the gap...
1979 z650 Resto-Mod
2018 Z900RS
  • Jack
01 Jan 2007 08:32
#102754
OK,thanks for the replies- much appreciated.What is the typical selling price for one of these swingarms? - I told my buddy I'd pay the going rate, but don't know what that is.
I'm going to keep the twin shock set up and have lower mounts fabbed like the GS swingarm conversion deal. Anubody done this rather than the mono conversion?
79 KZ 1075 MKll
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
  • wireman
  • wireman's Avatar
01 Jan 2007 11:02
#102789
yeah im in process of doing that myself with the twin shock mounts built into the extensions still trying to figure out shock mounting holes but ill get her done;) heres the unextended swingarm just sitting in frame on dining room table,what an understanding wife!:whistle: :P
Post edited by: wireman, at: 2007/01/01 14:05
  • wireman
  • wireman's Avatar
01 Jan 2007 11:08
#102791
heres the extensions for mine just need to free up some time to get back to work on it!;)
  • StreetfighterKz
02 Jan 2007 17:00
#103017
I paid $20 at a dragrace for mine. Plus another 20 for some homemade (sight unseen :() $25 or $35 for the shock linkage. I'm still looking for a decently priced Busa or Gsxr1000 shock. I was going to pay $50-75 on eBay if the swingarm came with everything (linkage, adjusters, etc.) Hope this helps.
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
  • 77KZ650
  • 77KZ650's Avatar
03 Jan 2007 23:33
#103293
Doug, check PM:whistle:
Scott
07 MDP Rookie of the Year
