Steering lock
- kzwolfsr
Steering lock
16 Dec 2006 15:56
I have a steering lock on my bike and its turnable like its working, but when I try to lock it it doesn't lock. This is what I do.... I put in the key and turn the key, then I turn the steering to feel for some kind of engagement and when I think that I have turned the bike enough without the steering bending or breaking my key, I turn the key back to its original insert position and the steering doesnt lock. My other friend with his Vulcan 500 did his for the first time since I told him it was there, and he got his to lock. I plan on just getting a pair of those handcuffs for bikes , but I want this thing to work
Original man of the Caribbean
- hydrolazer
Re: Steering lock
16 Dec 2006 17:02
try this,,,spray some wd-40 into the lock and keep working it. the tumbler has to push in so it will lock. just the key turning back and forth wont lock it. do the rest as you were doing it
\'79 kaw 1000 ltd
- kzwolfsr
Re: Steering lock
16 Dec 2006 17:35
So you are saying I will have to push the key in?
- hydrolazer
Re: Steering lock
16 Dec 2006 18:23
yes, at least i have to on my bike,i figure that they are all pretty much the same. when i got my bike i had trouble locking it also. i just lubed the tumbler and worked it back and forth untill it freed up and would push in when i turned the key. then it would lock
\'79 kaw 1000 ltd
- hydrolazer
Re: Steering lock
16 Dec 2006 18:23
\'79 kaw 1000 ltd
- Duck
- e vica na i sau na ga
Re: Steering lock
16 Dec 2006 18:46
careful
i do not know about your bike, but when i got my FT500 the lock wasn't working. i turned the key back to the position i found it in, went for a ride, came home, turned at the bottom of the drive, and it went ping, and locked. lucky it didn't do thayt while i was out and about. :-o
- Mark Wing
Re: Steering lock
16 Dec 2006 20:54
No worries of it locking by accident. On the KZ/LTD's you have to find the spot turn the key push it in then turn it back and remove the key.
Mark
Mark
Yorba Linda Cal.
Yorba Linda Cal.
- pumps
Re: Steering lock
16 Dec 2006 21:08
On mine you turn the handlebars to the right. Insert the key and push, then turn. You may have to move the handle bars back and forth just a little to find the spot. When I ride mine to the fire station I usually park inside the bay and lock the handle bars to prevent mischief from my fellow firefighters. Like coming out and it being parked around the corner or who knows where. Lubed mine with some "Zoom" turbine oil. With the patented "Telescoping Spout"! LOL
Check out our site. kcvjmc.org
1977 Yamaha XS650
2000 Kaw W650
2 KZ440 LTDs , a 79 KZ400H and an 83 Belt Drive
1977 Yamaha XS650
2000 Kaw W650
- KZ250LTD
Last edit: 04 Aug 2009 11:09 by KZ250LTD.
- JMKZHI
Last edit: 03 Dec 2008 11:20 by JMKZHI.
- pumps
Re: Steering lock
17 Dec 2006 12:06
I'm wondering if some of us aren't speaking of two different things. I BELIEVE on kzwolfsr's bike ( a kz650SR) similiar to mine what he is referring to is the fork lock. Located down low on the tripple tree on the left side. It is meant to lock the forks in position.I don't THINK he is referring to locking at the ignition. Am I right kzwolfsr? Or cornfused?
1977 Yamaha XS650
2000 Kaw W650
1977 Yamaha XS650
2000 Kaw W650
- kzwolfsr
Re: Steering lock
17 Dec 2006 19:57
Couldn't be any more right than I am. Thanks Pumps! Just the info I needed, I only used to put in the key and turn it, but it didn't do anything, Now I know to push it too!
